Mike-
Regarding 60m Fixed Frequency Requirements:
Referencing:
60 Meter FAQ
"For FCC equipment Certification (Formerly called Type Acceptance), does the radio have to be restricted to only transmit on these allocated channels (like Marine HF radios)? -"
"Part 97 transceivers do not require Certification. The method of incorporating the new center frequency channels (5332 kHz, 5348 kHz, 5358.5 kHz, 5373 kHz, and 5405 kHz), as specified in Section 97.303(s), into the device is at the manufacturer's discretion. The device must have capabilities so that the licensed amateur can operate the device in compliance with the Part 97 Rules. For 60 M operation, the tuning may be variable as long as the licensed amateur can tune to the specific frequencies listed in the rule. The device is not restricted for operation only in this band. The transceiver can have a PEP power output at the antenna terminal greater than the specified ERP as long as the operator can control the power so that the station does not transmit with more than 100 Watts ERP PEP."
