Old 12-08-2018, 5:58 PM
Default Raspberry Pi software to listen to just one UHF frequency?
I am getting a little bogged down in my searches on the subject...
What I want to do is listen to one UHF frequency, our repeater output, on a Raspberry Pi. I would prefer to run a headless Pi Zero W using VNC and planned on using an RTL-SDR v3. I will be running Zello under Wine so I will be stuck using the GUI. I think that I can handle the Zello portion but need some suggestions on a reliable free program to do the tuning. I want to use stock Rasbian.
Any suggestions on an application that can do what I want without a lot of hassle setting it up?
Old 12-08-2018, 7:43 PM
SDRPlayer's Avatar
If the frequency is known, is any reason why you can't use rtl_fm?
"Life is a series of events designed to interrupt my SDR time"
Old 12-08-2018, 10:22 PM
That looks like it will do the job. Thanks.
Old 12-08-2018, 10:31 PM
SDRPlayer's Avatar
No probs. Info and commands here: Rtl_fm Guide: Updates for rtl_fm overhaul
i use rtl_fm with my pi to keep the "overheads" low.
Old 12-08-2018, 10:49 PM
If I ran across that one in my searches, it didn't make the "memorable list" for some odd reason. However, it should feed the repeater output over to Zello just fine. I want to be able to monitor the repeater in a password protected channel when I'm too far from it. It's a temporary solution.
Old 12-09-2018, 4:21 AM
https://github.com/szpajder/RTLSDR-Airband
decodes am/fm. multichannel, stream audio or save to mp3.
