Fast food drive-through freqs.
KR4WM
Myrtle Beach, SC
Anyone know of an up-to-date database of fast food drive-through frequencies? In particular looking for the Myrtle Beach area. I'm trying to locate a source of interference, and I think this is where it might help me locate where it's coming from. It's very weak, but every once in awhile I pick up a syllable here and there. I've tried searching but came up empty handed, probably because of the intermittent nature of their transmissions. I've looked at the results from Google, and the most recent list was around 2003, way outdated.
Thanks, -KR4WM
AndersonMBK
I don't have a list, but it would be very easy to use a scanner with signal stalker to determine the frequency.
Or, the FCC database may be of some help.
License Search
ecps92
Taxachusetts
Altho the list was from 2003, many have not changed the basic lay-out since the 80's
when they were VHF Low and VHF High [split bands].
What Freq is getting the interference? Interference to what? commercial Radio, Scanner?
Thanks, -KR4WM
KR4WM
Myrtle Beach, SC
REPLY: What is being interfered with
My scanner. It's just random interference. Bits and pieces of syllables, not necessarily on the same channel that I can tell. I did hear "chi" (sounded like it might have been "chicken") and on another occasion what I thought sounded like "ad" (could have been part of the word "salad"). I think I know where the interference is coming from, but I don't want to call them on the carpet until I know for sure. Thanks, -KR4WM
texasemt13
CenTex DBA
Hunter, TX
How far are you from the nearest fast food places?
I have some programmed in and don't hear them more than 1/2mi. away if that. Some I only hear if I am in the drive-thru stopped on that freq.
It is rare that you would hear these interfere with many freqs. Usually they just step a little off their own freq so they would only be interfering with frequencies one or two steps above or below their own.
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
Keep in mind that the interference you're experiencing may be a problem on your end ... rather than theirs.
You might have problems with your coax or a connector, or a bad ground. An inline amp may be creating an overload situation. An antenna at your location that you use for something else - like amateur radio - might be acting as a passive amplifier of the offending signal.
If you do determine that the problem is on the other party's end, it might be more helpful to contact the person designed as the contact in the FCC ULS. Some restaurants are licensed under their corporate, franchise or a dba ("doing business as") name.
Good luck.
ecps92
Taxachusetts
On What Frequencies. Please be more specific
it will help in narrowing it down.
As for calling them on the carpet, if they are legal the resolution falls on you, not them
Check your system, it could be Cable TV leakage too [Especially VHF]
