I am a flight medic with LifeNet and want to listen when I'm off but don't know what type of scanner I need to buy. I know we operate on the Pal 800 system. Can someone help me out.
Welcome to RR.com!
Good to have you join us. I split your post off into its own thread as you will probably
get better answers to your questions that way.
Looking at the
Palmetto 800 system in the database it does appear that currently LifeNet uses analog talkgroups on the system. Which means that an analog trunking scanner such as the
Uniden BC346XT or the
GRE PSR-310 will work for you if you are on a budget. Do keep in mind though that if your agency decides to switch to a digital voice format then the 2 above scanners will no longer be able to monitor the comms.
You will need to consider a digital capable scanner like the ones in
THIS LIST.
Our Wiki here at RR.com has a wealth of information and our regular forum members are always happy to help out folks new to the hobby.
Thanks for being a part of RR.com and Happy Monitoring!
Marshall KE4ZNR
