kicktd
I'm in NC but very close to the Cherokee County border so pretty close to the Pal. 800 transmission site in Cherokee County.
A couple years ago before moving here while visiting I had no problems picking it up even using a handheld with a rubber ducky antenna. Now a couple years later after moving here I can't even get the Pal. 800 system using an outdoor antenna above the roof-line of the house.
I try the frequencies in the database but get nothing but dead air, not even a faint hint of a control channel, mean while I can pick up NC trunk channels in counties that are 2-3 counties away just fine.
Is the Pal. 800 system undergoing some type of change and are there new frequencies out there? I can pick up the York County Trunking System clear as a bell, but nothing for the Pal. 800 no matter if I try York County CC's or Cherokee County CC's. I've even tried Hogback Mtn. with no luck, like above not even the faint whisper of a control channel, just dead air.
So I'm turning to you guys who are in SC who monitor the system who can possibly point me in the right direction to get the Pal. 800 system back in my scanner and going.
Thanks!
Thanks!
