Ok, let's talk you through this. Pick an empty bank that you want to use as your bank for public safety. South Carolina uses a statewide radio system so you're going to hear ALOT of traffic on this once you get the freqs put in. So you're going to want to program in just the dorchester county talk groups and close the bank if that's all you want to listen to. Ok, So let's assume you choose bank 7 as your public safety bank. Press the prog button until you see the M before whatever channel you're on, then type in 700 to take you to channel 700.
Press program again until you see P700, then insert this frequency, 856.76250, then press ent and the up arrow unti you see P701, then insert this frequency, 857.46250 then press ent
Continue to do this with these frequencies, switching channels every time.
Channel 702-857.76250
Channel 703-858.46250
Channel 704-858.76250
Channel 705-859.46250
Channel 706-860.46250
Now press the arrow down until you're back on 700. Press the mode button three times until the channel reads P700Mo.
Repeat this for every channel. They should read--- P700mo P701mo P702mo P703mo P704mo P705mo P706mo.
Ok With me so far?
Now press FUNC-TRUNK and it should read "ID Bank 7 Trunking mode not selected, press Mode key." Press this once and it should now be a motorola type trunking system. You can now program in the applicable talk groups for Dorchester County. Those are as follows.
14640 393 A DorCo EMS 1 Dorchester Co. EMS Ch 1 Ops EMS Dispatch
14672 395 A DorCo EMS 2 Dorchester Co. EMS Ch 2 Night EMS-Tac
15088 3af A DorCo EMS 3 Dorchester Co. EMS Ch 3 Admin Law Talk
14688 396 A DorEMS Sumvl Dorchester Co. EMS to Summerville ER Hospital
14256 37b A DorEMS Roper Dorchester Co. EMS to Roper Northwoods ER Hospital
15056 3ad A DorEMS Wltrb Dorchester Co. EMS to Walterboro ER Hospital
14656 394 A DorEMS Tride Dorchester Co. EMS to Trident ER Hospital
14608 391 A DorCo FD RQ Dorchester Co. Fire Rescue Fire-Tac
14496 38a A DorCo FD Cmd Dorchester Co. Fire Rescue Command Fire-Tac
14352 381 A Drchster EOC Dorchester EOC Ops/EMS Command Emergency Ops
14544 38d A St George PD St. George PD Law Dispatch
Ignore all the middle numbers that start with 3, you won't need those. Ignore 393, 395, 3af etc. When you program one in you can press text and type in the name of the talk group.
I hope this helps. I work tomorrow then I'm off for a week. If you need more help send me an e-mail at
kf5qgf@live.com and we'll work through it.
Craig
KF5QGF
