Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > South Carolina Radio Discussion Forum
South Carolina Radio Discussion Forum - Forum for discussing Radio Information in the State of South Carolina.
Old 04-01-2017, 8:09 PM
Signal-Zero's Avatar
Default SC DPS Highway Patrol cutover to Palmetto P25....
Time to start logging the Site ID, RFSS and talkgroups....
Highway Patrol Troop 6 + Holly Hill – June 19-23, 2017.
(Jasper, Beaufort, Colleton, Dorchester, Charleston, Berkeley)
Highway Patrol Troop 5 + Chesterfield – June 26-30, 2017.
(Williamsburg, Georgetown, Horry, Marion, Florence Dillon, Marlboro, Darlington, Chesterfield)
Master-Site Reconfiguration – July 2-21, 2017
Highway Patrol Troop 7 + Augusta, GA – July 31-August 4, 2017
(Orangeburg, Calhoun, Bamberg, Allendale, Hampton, Barnwell, Aiken)
Highway Patrol Troop 1 + Sandy Run – August 14-18, 2017.
(Lexington, Richland, Kershaw, Lee, Sumter, Clarendon)
Highway Patrol Troop 2 – August 28-September 1, 2017.
(Newberry, Laurens, Saluda, Edgefield, McCormick, Greenwood, Abbeville)
Highway Patrol Troop 4 – September 11-15, 2017.
(Lancaster, York, Chester, Chesterfield, Fairfield)
Highway Patrol Troop 3 + Cherokee – September 25-29, 2017.
(Spartanburg, Greenville, Anderson, Pickens, Oconee, Cherokee)
http://www.masc.sc/SiteCollectionDoc...2003-07-17.pdf
"We celebrate our independence from the Government, not our dependence on it."
Old 04-01-2017, 8:47 PM
milf's Avatar
Careful, I CAN hear you!
Lowcountry first, then East Coastal... Then inland , and ending with Upstate. Anyone know if they are going multi zone/multi core, or going with just one in Cola?
PRO-92, PRO-92B, PRO-96 x 2, BCD396XT, BCD436HP+DMR
HT-1250 LS+, APX6000XE
Old 04-01-2017, 9:08 PM
From what I'm reading online looks like all one core Should use same system ID as the current P25 system used by Charleston, etc.
Old 04-02-2017, 10:32 AM
The attached document states, "No encryption fee is charged in the P25 fees." The existing Palmetto-800 system had surcharges for encryption. Now, without additional costs for encryption, we may see many more (if not all) agencies switch to encryption. Not good!
Old 04-02-2017, 12:58 PM
The reason for the surcharge was the talkgroups that were ENC were digital in the Smartzone. Since all P25 systems are purely digital, I believe this is the reason for not charging the additional fee. Most subscribers come standard now with minimum ADP, but most agencies won't use it since its weak encryption compared to DES or AES-256. Plus, under DHS SAFECOM the State would lose the funding if it's not 256 bit standard which would cause a hardware upgrade to the subscriber units at a significant cost. I've only seen re agencies go ENC when the system switches to Phase II because the XTL and XTS subscribers don't support TDMA. So when they order new APX subscribers, they get all the bells and whistles. But the switch to a Phase I from Smartzone only requires reprogramming. So I don't see it. If so, PD yes like Beaufort County but traditionally Fire/EMS sees right through that and understands interop can be affected.
Old 04-02-2017, 7:50 PM
DB Administrator
Beaufort County, incidentally, encrypts EMS dispatch and ops channels, but not MED channels to hospitals. Also, some Beaufort County FDs have encrypted TAC and Ops channels. HHI Fire/Rescue is in the clear.
Fortunately, for now, Beaufort County seems to be an outlier in respect to encryption. And I hope it stays that way.
milf's Avatar
Also Florence
Sent from my LG-K330 using Tapatalk
Old 04-12-2017, 2:52 AM
Caesar's Avatar
Brian, I hope you are ready for daily updating! lol, i've got my disc tap/Trunk88 ready!
Old 04-12-2017, 2:54 AM
Caesar's Avatar
That is the order each county is switching over, they are using Highway Patrol Troops, but it will be every agency on pal8 in those counties.
Old 04-12-2017, 9:38 AM
lite_c's Avatar
That is what I was wondering, considering the memo is addressed to all users and agencies. I think they are working by troops and going by comms center (DPS/SCHP dispatch center in each troop), but that is only to organize the switch. Seeing that it concerns all users and addresses "all master sites," it should be all agencies switching over.
Old 04-12-2017, 9:08 PM
Correct, all Palmetto 800 users will switch to the Palmetto P25. New system ID and new talkgroup. All the sites will be upgraded. The new system is a Motorola P25 - 7.15 Core which utilizes Motorola Smart-X technology to migrate the network’s remaining 4.1 SmartZone sites to P25.
Old 04-12-2017, 9:09 PM
Caesar...bring it !!!
Old 04-13-2017, 6:28 AM
DB Administrator
I'm always ready for updates, Caesar. No worries there. I've enjoying working all of the excellent submissions for the new Horry County system over the last few weeks. I hope we'll have folks from all over the state listening, making notes, keeping logs, and submitting information in a timely manner once the P25 cutover process begins in a couple of months.
Keep in mind that Trunk88 is a 3600bps control channel decoder only, it won't do you any good with P25 control channels. You'll want to get set up with Unitrunker or Pro96Com to gather data for the new sites. I highly recommend this method of monitoring and logging. I have my station set up also ready to go.
A couple of comments about submissions:
- Always use the formal submission process through this website. If you post information to the forums, I'll see it but it may take longer for the information to be updated in the database.
- You can remain anonymous when you submit information through the submission system.
- When possible, please submit information in the preferred formatting. This makes processing submissions for talkgroup updates easier for me. The formatting information is displayed as part of the submission process.
Old 05-18-2017, 4:12 PM
EDIT: Disregard...
Old 05-18-2017, 4:35 PM
milf's Avatar
Have fun Brian. I just went through this with SAFE-T upgrades to P25. And in couple of years get to do the Phase II upgrades. AWIN is about to start Phase II upgrade so fun all around.
Old 06-18-2017, 11:51 AM
milf's Avatar
Get your scanners set to monitor P25 Low Country, Switchover starts tomorrow. Set up a new system, use the current Palmetto freqs, but set it up as P25, and ID search. I don't know the timing they have in mind, but will guess if its like every other switch they do, it will be after 10 PM thru say 4 AM? Also have your Pro96Com, Unitrunker, Discovery/Analyze etc ready to nab Site #, Site NAC, Adjacent Sites, Primary CC, Alternate CC, etc ready.
Old 06-20-2017, 1:28 PM
mckinscan's Avatar
Spartanburg county will switch around September 25
LMckinney
Old 06-20-2017, 1:37 PM
Default South Carolina
Will be looking for inter-op Tg for North Carolina they used to be around five
Old 06-21-2017, 10:41 AM
jeffmulter's Avatar
Location: Fort Mill, S.C. (just south of Charlotte, N.C.)
SCHP Troop 4 / Chester includes NCHP Troop H dispatch in Monroe (east of Charlotte) among the agencies they call up during a roll call performed during the early morning hours. The roll call is performed on the S.C. mutual aid 4 talkgroup.
It is possible that there is a similar arrangement between SCHP Troop 3 and NCHP Asheville / Newton dispatch, as well as SCHP Troop 5 and NCHP Elizabethtown (Clarkton) Troop B dispatch.
Old 06-22-2017, 9:47 AM
Thanks for info
