It's not unusual for some SCHP dispatch talkgroups to be patched together at times. This allows a single dispatcher to work more than one channel as if it was a single channel, and does not require any change on the subscriber radios. This is very common in Troop 7.
It may be that when the Pickens/Oconee and Anderson dispatch channels are patched, the "master" talkgroup is the Anderson channel. Depending on the radio you're using and how it handles patched talkgroups, you may not be able to tell what's happening.
Example, occasionally the Greenville and Spartanburg SCHP channels are patched, usually overnight and morning times. I generally have Spartanburg unlocked and Greenville locked out. On my GRE/RadioShack/Whistler scanners, the Spartanburg group will be active, but instead of seeing "TGRP" in the display, I see "ptch". Indicating that the Spartanburg group is patched and is not the "master" talkgroup of the patch.
Some scanners don't support patching, and the talkgroup will be silent even if it's part of a patch and active.
