I have both the 996P2 and a BCD436HP when I monitor the Oconee County Sheriff they are DMR I said motorboat in the subject sorry,with the 996P2 I get s lot of Data noise! But the BCD436HP filters it all out? Is this a limitation of the P2 that it doesn’t always filter this out? It’s so bad that I stopped using the P2 for the sheriffs office! They are both programmed as close to the same as possible except the BCD436HP uses the internal database and the P2 used RRs database off the net? Am I missing something? At first I thought the P2 was monitoring the control channel but if I L/O the channel I never here anything and the BCD436HP is the only radio I can hear the sheriffs office on! The P2 should be more sensitive since it has a better antenna. Any ideas? I’m actually thinking of selling the P2 and replacing it with a BCD536HP
