Go Back   The RadioReference.com Forums > Service Specific Monitoring > Sports and Recreational Events
Sports and Recreational Events - For discussion of radio communications used in sports and recreational events. For example, NASCAR, NFL, PGA, Indy, Moto GP, etc. For track or stadium specific comms please use its Regional forum.
Old 05-31-2017, 1:53 AM
Default Supercars 2017 Race Frequencies
Hi all,
Firstly, I wasn't quite sure what category to place this under so moderators, please move to appropriate section if required.
I was wondering if anyone knows where I can locate the team radio frequencies for the Australian Supercars (aka V8 Supercars) for events this year? Once upon a time they use to have it on their website but now it appears not.
I can only seem to find frequencies from 2015 or even earlier doing Google searches
Your help would be greatly appreciated.
Old 05-31-2017, 7:21 PM
SDRPlayer's Avatar
G'day, last weekend at Winton they started at 500.325 through to about 501.200. I used dsd+ to decode the NXDN. Hope that helps you.
Old 05-31-2017, 8:21 PM
Thanks SDR,
Not sure what the whole dsd+ and NXDN means but I appreciate your help.
I have a Uniden UBCD436-PT so I should be able to pick these frequencies up yeah?
Old 05-31-2017, 8:30 PM
SDRPlayer's Avatar
Freqs won't be an issue, the teams are running digital Kenwood radios, so if your UBCD436-PT decodes NXDN you will right to go. Otherwise you will need a decoder setup (DSD+).
Old 07-04-2017, 4:16 PM
Originally Posted by Exceler8r View Post
Thanks SDR,
You'll need a Whistler TRX, an AOR DV-1 or a tapped scanner/sdr radio with DSD+ to decode NXDN.
Old 07-05-2017, 2:14 AM
Ok, again, too much jargon and mumbo-jumbo there...
Old 07-05-2017, 3:58 PM
Google is likely to be your friend here......
Supercars use a digital radio system called NXDN. It's provided by Kenwood. They make radios. To listen to NXDN, you need a specific type of scanner. Whistler offer two scanners - the TRX1 and TRX 2 that decode NXDN. AOR make the other type of NXDN capable scanner called the DV-1. Based on your response the DSD+:method is likely to be way beyond your technical abilities. In saying that, I wouldnt recommend any of the above scanners for a novice. Your uniden doesn't decode NXDN.
