  #21 (permalink)
Old 10-20-2016, 7:07 AM
Originally Posted by hazard78 View Post
how do I fix this error
DarkIce: LameLibEncoder.cpp:75: lame lib opening underlying sink error [0]
thanks
Hi..
Have you been able to sort this problem out. I had a similar issue and it turned out that I had the wrong password set in the darkice1.cfg file
Make sure it is the same password set for the icecast server - default is 'hackme' if you haven't altered the original settings of the icecast server.
Declan
  #22 (permalink)
Old 12-02-2016, 8:31 PM
From the Darkice website,
lame lib opening underlying sink error [0]" mostly has nothing to do with lame
itself but with the server you are streaming to. Please check host, port,
username, password, mountpoint,
Double check that everything is correct, see if that helps.
  #23 (permalink)
Old 06-22-2017, 3:46 PM
Default This worked for me
I have that same error. The IceCast server had my mountpoint as "/stream" I changed the darkice.cfg file mountpoint to "stream" and this worked
