  #41 (permalink)
Old 01-23-2011, 12:58 PM
richtidd's Avatar
Live Audio Administrator
Originally Posted by ProScan View Post
I just released RadioFeed 1.2. A no cost solution.
Streams audio to RadioReference, Icecast, and ShoutCast servers using the Source Client feature or directly to media players using the Web Server feature.
Available at ProScan on the right side of the page.
  • Fixed - Win 7 not writing the configuration and log files if installed in the "Program Files (x86)" folder.
  • Changed - Selecting RadioReference server type in the Source Client locks the Samples Per Second at 22050 and MP3 Bitrate at 16(Mono) / 32(Stereo) kbps.
  • Changed - RadioReference Auto Configure in the Source Cient can now pick feed by description instead of mount if running multiple feeds.
I will be working on the the Wiki next and then on to the GRE scanners.
However, the zip file, download file in the zip & the installed about say v1.1. and the features are 1.1.
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo
  #42 (permalink)
Old 01-23-2011, 1:02 PM
ProScan's Avatar
Originally Posted by richtidd View Post
Good for catching it early. I forgot to update the home page. It should work now.
Most Popular & Feature-Rich Scanner Software For The Uniden's
ProScan - RadioFeed Home Page
bob@proscan.org
  #43 (permalink)
Old 01-23-2011, 1:08 PM
richtidd's Avatar
Still says the same for me.
Richard Tidd
Broadcastify.com
My online scanners:
SMCo
  #44 (permalink)
Old 01-23-2011, 1:16 PM
ProScan's Avatar
Try refreshing your browser. F5 key.
bob@proscan.org
  #45 (permalink)
Old 01-23-2011, 1:26 PM
richtidd's Avatar
I had done that several times but at first did not change.
But finally it did & 2.0 is there.
Richard Tidd
Broadcastify.com
My online scanners:
SMCo
  #46 (permalink)
Old 01-25-2011, 8:12 PM
ProScan's Avatar
Default RadioFeed 1.3 Out
This version only has a few changes but I wanted to get this out as the next version will be a few weeks away.
Next version will have PSR-500/PSR-600 support. Anyone interested in testing, email me so I can send you a test copy.
RadioFeed 1.3 available at ProScan on the right side of the page.
  • Added - Web Server - Shows the local and outside IP addresses.
  • RadioReference Auto Configure only way to configure. Manual method no longer permitted to prevent mis-configurations.
RadioFeed streams audio to RadioReference, Icecast, and ShoutCast servers using the Source Client feature or directly to media players using the Web Server feature.
bob@proscan.org
  #47 (permalink)
Old 01-25-2011, 8:29 PM
richtidd's Avatar
V1.3 looks good.
Works fine.
Richard Tidd
Broadcastify.com
My online scanners:
SMCo
  #48 (permalink)
Old 01-26-2011, 3:59 AM
Just Installed up and running in seconds Thanks Bob perfect integration.
Cheers Sly
  #49 (permalink)
Old 01-26-2011, 1:57 PM
NYRHKY94's Avatar
E-mail sent for a copy of the next release to test with a PSR-600.
Thanks - Mike
BCD536HP/BCD436HP/BCD996P2/BCD325P2/BCD996XT/BCT15X/PRO-197/PSR-600
  #50 (permalink)
Old 01-28-2011, 10:56 AM
EdmontonFireRadio's Avatar
Just installed version 1.3 and wanted to mention a couple of things.
Is there a way to have the program automatically check every so often for an update? This may help people that use your software but they don't really keep an eye on your website or this forum to keep up to date with the latest release.
Is there any way to disable the baloon tip that shows when we minimize to the system tray? The first time is fine, but it gets to be a little annoying after you are running the program for a while but like to check every so often to make sure it is still working properly.
Thanks,
Jeff
  #51 (permalink)
Old 01-30-2011, 11:07 PM
ProScan's Avatar
Default RadioFeed 1.4
RadioFeed is available at the ProScan web site on the right side of the page.
  • Added - RS/GRE Scanners Text Tag Support - PRO-106, PRO-197, PSR-500, and the PSR-600.
RadioFeed is a no cost solution.
bob@proscan.org
  #52 (permalink)
Old 02-01-2011, 9:05 PM
ScanPEI's Avatar
I really like this program. Easy to use and works great.
I added the program to the startup menu so it will start when the computer turns on but it does not automatically connect. Should it do that or am I missing something?
Daniel Deziel
ScanPEI
Database Admin for Prince Edward Island and New Brunswick.
  #53 (permalink)
Old 02-02-2011, 3:24 AM
ProScan's Avatar
Make sure the option is checked "Start Up - Source Client & Web Server Use Last State When Program Closed"
bob@proscan.org
  #54 (permalink)
Old 02-02-2011, 4:11 AM
ScanPEI's Avatar
Yes that was checked. Wonder why it didn't work. hmmm. I shall try it again.
EDIT: Tried it again and it worked fine. Thanks
Daniel Deziel
ScanPEI
  #55 (permalink)
Old 02-02-2011, 8:16 AM
ProScan's Avatar
One possibility why it didn't work the first time is the Source Client may have been in the disconnected state when the program closed before the computer rebooted.
bob@proscan.org
  #56 (permalink)
Old 02-02-2011, 9:11 AM
johnvassel's Avatar
My program doesn't care if using 2.0 or 4.0. RadioFeed is not using anything that's new in 4.0. I decided to target the 2.0 net framework for two reasons.
1) 4.0 doesn't work on Win 98 and 2.0 does. 2) ProScan in the past targeted 2.0 so if anyone using ProScan and now want's to use RadioFeed. They dont have to wait for 4.0 to be installed if they don't have 4.0.
AS I read down the thread I kept thinking 'crap', my now freed up pc for streaming is running 98, so much for proscan.
Glad to see this change.
I may give it a try today.
  #57 (permalink)
Old 02-02-2011, 9:31 AM
johnvassel's Avatar
Okay, I put my feed on radiofeed. I notice punchier audio and much less lag in 'real time' audio.
Thanks!!
I liked the slider too, dumped the unused channel on my input to 0%, perhaps this is where the louder audio comes in?
Edited to add:
I really like this. Hopefully it stays stable.
Now, in development, I'm wondering if there is a way to put a 'bottom' on the audio input slider.
For example, when I was using my oldest laptop, it only had mic in. This created a bottom of the signal noise that was broadcast in the feed.
I've since switched to a slightly newer laptop that has a line in, but it'd still be nice to put a 'bottom' on the input, nothing below that threshold being streamed.
  #58 (permalink)
Old 02-02-2011, 1:57 PM
ProScan's Avatar
Thanks!!
Edited to add:
I'm glad you like it and nice to hear that it's performing to specs. I do recommend that the unconnected input be at 0% so it won't pickup unwanted audio mixing with the desired audio.
This will stay stable (knock on chrome...I mean bytes). It is time tested with the same feature in ProScan ScanCast.
I'm not sure about the ideal that the audio has to be above a threshold is good because I can see the complaints of the audio cutting in and out. My development machine has a stereo mic input that I use and it doesn't have that problem. I think DSP would be a better route.
bob@proscan.org
  #59 (permalink)
Old 02-07-2011, 7:48 AM
ProScan's Avatar
Thanks,
Jeff
Good suggestions.
I'll add a "Check For Newer Versions" option that will check for updates when starting up and every hour.
I will also take out the notification balloon tip and keep the balloon text.
bob@proscan.org
  #60 (permalink)
Old 02-12-2011, 12:51 PM
Any plans on support for PRO-96 text tags?
