  #2941 (permalink)
Old 02-05-2016, 3:40 PM
ffryan76's Avatar
Originally Posted by sc2142 View Post
I dont know what the problem is, but every now and then this will happen... AMR Also does not seem to work for me. Anyone know what the issue is?
It seems you don't have ffmpeg installed in your TTD folder.
There is a link to download ffmpeg on the TTD website.
  #2942 (permalink)
Old 02-05-2016, 3:46 PM
Exclamation Unable to get FTO working Correctly
I'm having a hard time getting TwoTone to send a page on only the FTO of a local fire department. To start off I have uploaded a .zip file of the FTO for additional troubleshooting.
I typically will receive an email with a little radio traffic on it - but its not because the Tone was activated by dispatch. It might have been a key-up or something in that nature. Maybe I'm not processing the 2-tone as the one this department uses so that's why I uploaded a sample.
Tone Editor Settings:
A Tone: 800
B Tone: 1500
A tone Length: .25
B tone Length: .25
TwoToneDetect v68 Settings:
Record Sec: 30
Record Release timeL 3.0
Tone Tolerance: 1.0
Tone Offset: 0.0
  #2943 (permalink)
Old 02-05-2016, 4:54 PM
Thanks now i wait, Will this fix the AMR Also?
  #2944 (permalink)
Old 02-05-2016, 5:51 PM
ffryan76's Avatar
Yes it will.
  #2945 (permalink)
Old 02-05-2016, 5:58 PM
A Tone: 800
B Tone: 1500
A tone Length: .25
B tone Length: .25
Record Sec: 30
Tone Tolerance: 1.0
Tone Offset: 0.0
That is not a standard TwoTone. It is more of just an alert tone to get your attention. It is going to be quite hard to get TTD to reliably decode that tone. Is there a two tone sequence prior to the warbling alert tone?
  #2946 (permalink)
Old 02-05-2016, 6:11 PM
A Tone: 800
B Tone: 1500
A tone Length: .25
B tone Length: .25
Record Sec: 30
Tone Tolerance: 1.0
Tone Offset: 0.0
TTD works with 200ms audio samples. your tones have a length of 250ms. So you are asking it to decode on one sample of the Atone followed by one sample of the Btone. Yes, you will regularly get false activations by normal radio traffic with this setup.
  #2947 (permalink)
Old 02-05-2016, 9:52 PM
I figured that wasn't a standard TwoTone - That alert is the FTO this department uses.No other tones are used when they dispatch.
  #2948 (permalink)
Old 02-06-2016, 11:46 AM
Still not working
  #2949 (permalink)
Old 02-06-2016, 12:07 PM
ffryan76's Avatar
Still not working
You have the ffmpeg.exe file in the same folder as TTD? If so, double click on the ffmpeg.exe file to start it.
  #2950 (permalink)
Old 02-06-2016, 12:30 PM
Just did that again, Ill post back when a call come through. Ive ran Both As Administrator.
  #2951 (permalink)
Old 02-06-2016, 8:15 PM
Its still not sending the email.
  #2952 (permalink)
Old 02-06-2016, 8:23 PM
ffryan76's Avatar
I would post your log file here so myself and others can see what might be the issue.
I've had this issue myself. I can't remember what I had forgotten to set up to get it to work correctly.
  #2953 (permalink)
Old 02-06-2016, 8:25 PM
ffryan76's Avatar
I have them in separate folders/directories named something different in both. I still get the warning. Both are running though.
I figured out I had a setup incorrect.
  #2954 (permalink)
Old 02-06-2016, 8:36 PM
This? https://dl.dropboxusercontent.com/u/..._26_904000.txt
File was to big to attach.
  #2955 (permalink)
Old 02-07-2016, 5:47 AM
For starters, turn your audio threshold up. Set it manually in the config.cfg file to about 400.
  #2956 (permalink)
Old 02-07-2016, 9:49 AM
Done
  #2957 (permalink)
Old 02-07-2016, 2:53 PM
Done
Recived One Call And Email, No AMR.
  #2958 (permalink)
Old 02-07-2016, 3:00 PM
ffryan76's Avatar
I think your email setup is the issue. If you are using gmail you will have to set up a app password for the ttd. Then place that password in your setup for ttd.
  #2959 (permalink)
Old 02-07-2016, 3:05 PM
So, Access for less secure apps?
  #2960 (permalink)
Old 02-07-2016, 3:07 PM
ffryan76's Avatar
Start here https://support.google.com/accounts/answer/185833?hl=en
Tags
twotonedetect
