Trying to use BCD396-XT for live feed. This works thru microphone of PC but that's it. I thought it would run thru PC sound card and PC microphone would not be used. Am i'm configuring wrong????
You need to have a data cable and an audio cable. There seems to be a general misconception that audio will go through the data cable. Not sure if this is what you are asking or not.
You need an audio cable attached between the scanner and your MIC port on your sound card. Some use "line in". I have used both. I am a little confused by what your asking? Do you have both a PC mic and a soundcard mic ?
OK ....... So, the cable that connects the BCD396-XT to the computer and runs the software programs isn't enough to do the data and audio? Sorry, but I'm really only learning this stuff.
I do not have that setup but I do not believe so. None of the instructions indicate that. I believe you NEED an audio cable no matter if you have the data cable or not.
