  #701 (permalink)
Old 01-01-2018, 10:59 AM
davidVT's Avatar
Originally Posted by aaknitt View Post
Hi everyone,
Thanks to the efforts of DC31 and others, I've had some success building a TwoToneDetect executable file that will run on the Raspberry Pi. This executable bundles all of the Python dependencies, which greatly reduces the number of steps needed to get TTD running on a stock Pi OS image.
The instructions on the website for getting TTD running on a Pi had gotten pretty out of date, so I updated them today using the new executable files that I just posted on the site. The updated page is here:
TwoToneDetect on a Raspberry Pi | TwoToneDetect
For those running TTD on a Pi, please take a look and let me know if these instructions work for you, if there are things that are unclear, should be added, etc.
Thanks,
Andy
Andy, sounds great. I will try this evening on a clean Pi.
Question, can I just drag and drop existing tones, redundant and config files from earlier TTD versions??
Thank you
  #702 (permalink)
Old 01-01-2018, 11:04 AM
Thank you
Yes that should be fine, just do it after uncompressing the downloaded files to replace the generic ones that come with the package.
Andy
If you need help with TwoToneDetect please read this post first
  #703 (permalink)
Old 01-03-2018, 9:55 AM
Default TTD70 Pi image
I have set up TTD70 on a pi3 and made an image that should be downloadable for those interested in trying it out on a pi. I tried to keep this image as minimal as possible to cut down on upload/download time, etc. The compressed image is 1.31 Gb so it still may take you an hour to download it. After extracting, it will be around 3.95 Gb, might fit on a 4 Gb card but definitely will fit on an 8 Gb. Username is pi, password is ttd-v70. Hostname is ttd-v70
1. Download the compressed file.
https://drive.google.com/open?id=13q...n46_iGzjUNq8al
2. Extract the tar.gz file to an .img file using 7-Zip, WinZip, or whatever works for you.
3. Image an SD card with this .img file. Etcher (from etcher.io) is a good tool for imaging cards.
4. Put the imaged card into your pi. Plug in your usb sound card. Connect an ethernet cable.
5. a. At this point you can connect an hdmi monitor and keyboard/mouse then power the pi up.
b. Alternatively, you may omit the monitor/keyboard and connect via ssh or vnc. Real VNC is running and available at ttd-v70.local:5900 on the same network.
6. TTD will load after about 30 seconds. Use the Edit Config Info button in the TTD window to set up that information. There is an icon on the desktop that can be used to edit the Tones.cfg information. Make sure that you save this information.
7. After you have made edits to these files, your best bet is to reboot the pi. (Remember that any time you make changes, other than to email addresses, TTD needs to restart to read these changes) Go to the raspberry icon at the upper left then choose Shutdown/Reboot.
One of the quirks with this setup is that Pulse Audio Volume Control needs to be running prior to starting TTD. Starting TTD by rebooting the pi takes care of this for you.
8. Features:
a. TTD autostarts on boot of the pi.
b. The pi reboots automatically daily at midnight.
c. The audio files are automatically deleted from the TTD/audio folder after two days.
d. RealVNC is enabled. this allows access to the GUI from your local network and can be set up to allow access from the internet with a RealVNC cloud account. (free and simple)
e. Runs well on wifi on a pi3.
Disclaimer: This image has not been thoroughly tested. It has been tested enough to see that it works and the common issues are taken care of. If you find other issues, post the error messages here and we can figure them out.
Let me know how it works for you if you try it.
Jim
  #704 (permalink)
Old 01-03-2018, 10:43 AM
nosoup4u's Avatar
I can confirm that this image is working great! I just cut my system over from my windows system and after editing my post processing scripts, it works perfectly.
John - KC2KZZ
http://www.warrenskywarn.org
SDS100, BCD536HP, BCD436HP, Home Patrol-2 , BC125AT and other old crap.
@kc2kzz - My Twitter feed. @WCAlerts - Warren County Fire/EMS alerts
  #705 (permalink)
Old 01-05-2018, 6:59 PM
ffryan76's Avatar
Jim
How to you change the tar file to an img file?
  #706 (permalink)
Old 01-05-2018, 8:48 PM
To do it from the linux command line:
https://www.interserver.net/tips/kb/...-command-line/
  #707 (permalink)
Old 01-05-2018, 9:08 PM
ffryan76's Avatar
I was trying to do it via windows to put it on the SD card. My mistake.
Sent from my SM-G920V using Tapatalk
  #708 (permalink)
Old 01-08-2018, 11:50 AM
8. Features:
Jim
The problems that you have been having were my fault. When doing the compression I used an incorrect file name. I have compressed the file again and uploaded a new version that hopefully will work better.
https://drive.google.com/open?id=1Dp...PHDjaG_17iw8ph
  #709 (permalink)
Old 01-08-2018, 4:00 PM
ffryan76's Avatar
Well it's about time. Just kidding.
Thank you for even coming up with this for us that have ADD for coding and have Google search deficiencies.
  #710 (permalink)
Old 01-08-2018, 6:53 PM
ffryan76's Avatar
Jim,
Had a issue when I loaded it into etcher. I got a notification the the image file wasn't bootable.
I did load it onto a card but it didn't run.
  #711 (permalink)
Old 01-09-2018, 10:17 AM
Angry
Jim,
yes, something is happening to the file during compression and upload/download. I agree, it doesn't work.
  #712 (permalink)
Old 01-10-2018, 9:44 PM
angry little Pi img file isn't it
  #713 (permalink)
Old 01-10-2018, 9:53 PM
Heh we can torrent it. :-p I'd seed it from my OVH server.
  #714 (permalink)
Old 01-15-2018, 9:20 PM
DC31 sent me an uncompressed img file at 2.9GB and it worked on my Pi3. So pending his approval I setup a .torrent tracker so we can send it out to everyone without killing his google drive account.
  #715 (permalink)
Old 01-16-2018, 5:28 AM
Go for it. Good luck.
  #716 (permalink)
Old 01-16-2018, 7:58 AM
Here is the .torrent file https://drive.google.com/open?id=1yT...Fzghyw3a78nUQz If no one uses it after a week I might as well take it down.
  #717 (permalink)
Old 01-18-2018, 3:30 PM
ffryan76's Avatar
Code:
  File "TwoToneDetect70.py", line 543, in alert
  File "dist-packages/pyaudio.py", line 750, in open
IOError: [Errno -9997] Invalid sample rate
338.0 2839.28949409
after record
delay timer NAFD Fire ST1 16:15:19 on 01/18/18
  File "TwoToneDetect70.py", line 675, in alert
UnboundLocalError: local variable 'recordstream' referenced before assignment
So, I'm stuck. I think this has everything to do with my audio setup but I can't quite fix it. I have two USB Sound cards. The first card, 0, is for TTD70. The second card I will use for streaming to broadcastify. What is the error I am getting located above?
Also, TTD70 will not execute without PAVolume being open first.
  #718 (permalink)
Old 01-23-2018, 8:00 PM
Code:
338.0 2839.28949409
after record
For the record, two fixes were attempted:
1. Both usb sound cards were configured for input only. The TTD window had audio output going to a USB sound card. That was changed to the ALSA on-board sound card.
2. Pyaudio was installed. sudo pip install python-pyaudio
(not really sure which if either of these fixed the issue, but the program now sends emails with attachments!)
FTP server upload was also failing. This will happen if there are any spaces in the Description parameter in tones.cfg Use underscores.
Ryan's ftp server password includes a single quote ' This may be causing authentication errors. Still working on this one.
  #719 (permalink)
Old 01-30-2018, 3:18 PM
ffryan76's Avatar
Default FTP with Raspberry Pi
This is sort of on topic but kinda not.
Has anyone tried to do an FTP on a pi for Twotonedetect mp3s? If you have, is it difficult to get it running? Do you have instructions a=on how to do it?
  #720 (permalink)
Old 03-05-2018, 8:52 AM
jeffycc's Avatar
Default TTD-No AMR/MP3 Emails
TTD Installed on Pi3, OS is Raspbian Stretch.
I get the Text-Only email when my tone goes off. I do not receive any AMR or MP3 email with the tone. Is this an issue with FFMPEG?
I did the command below:
sudo apt-get install ffmpeg
After install, I had to go find the ffmpeg which I found under directory .usr/bin
Is this the correct ffmpeg?
Thanks!
Jeff
