The RadioReference.com Forums
-   Streaming / Broadcasting / Audio Recording (https://forums.radioreference.com/streaming-broadcasting-audio-recording/)
-   -   TwoToneDetect on a Raspberry Pi - How To (https://forums.radioreference.com/streaming-broadcasting-audio-recording/262868-twotonedetect-raspberry-pi-how.html)
aaknitt 03-17-2013 7:32 PM
Hi everyone,
I finally had some time to put together a page showing how I got TwoToneDetect running on a Raspberry Pi. Along with a cheap receiver, this could allow you to have a TTD setup up and running that uses very little power for under $100.
I'm by no means a Linux guru, so if you run into problems trying to duplicate this I'm not sure how much help I'll be, but feel free to post here if you'd like. I thought I'd start a new thread to keep the Linux stuff separate from the main Windows version of TTD.
Regards,
Andy
krokus 03-18-2013 5:14 AM
Re: TwoToneDetect on a Raspberry Pi - How To
Would the RaspberryPi's built-in audio not work?
aaknitt 03-18-2013 9:25 AM
It has a built in analog audio out, but no analog audio input.
Andy
VA7DMZ 03-19-2013 1:16 AM
I followed your page and tried setting up my raspberry pi and I will mention a few issues I came across.
The '/etc/pulse/daemon.conf' file did not exist.
I had to 'apt-get install pulseaudio' for it to be there.
Thats the only real problem I had, but in the end it is not working still. here is the error im getting.
Code:
pi@raspberrypi ~/dist $ python TwoToneDetect59Pi.pyc
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.BRCM bcm2835 AL.pcm.front.0:CARD=0'
ALSA lib conf.c:4241:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4720:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.BRCM bcm2835 AL.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.BRCM bcm2835 AL.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.BRCM bcm2835 AL.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1286:(snd_func_refer) Unable to find definition 'cards.BRCM bcm2835 AL.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
ALSA lib pcm_dmix.c:1018:(snd_pcm_dmix_open) unable to open slave
  File "TwoToneDetect59Pi.py", line 104, in <module>
  File "/usr/local/lib/python2.7/dist-packages/iniparse/compat.py", line 135, in getint
    return int(self.get(section, option))
NoOptionError: No option 'control_scanner' in section: 'Section1'
Succesfully retrieved local tone info
Longtone1
defaultdict(<type 'list'>, {'Long Tone Page': array([ 604.,  604.,  604.,  604.,  604.,  604.,  604.,  604.,  604.,
        604.,  604.,  604.,  604.,  604.,  604.])})
defaultdict(<type 'list'>, {'Long Tone Page': 0})
  File "TwoToneDetect59Pi.py", line 661, in <module>
NameError: name 'input_device' is not defined
  File "TwoToneDetect59Pi.py", line 684, in <module>
  File "TwoToneDetect59Pi.py", line 673, in record
NameError: global name 'stream' is not defined
Here is when I run LevelControl.pyc
Code:
pi@raspberrypi ~/dist $ python LevelMeter.pyc
AUDIO DEVICE LISTING:
Output Device 0: bcm2835 ALSA: bcm2835 ALSA (hw:0,0)
Output Device 1: sysdefault
Input Device 2: pulse
Output Device 2: pulse
Output Device 3: mmap0
Output Device 4: default
Enter input device index:
I set config.cfg for the pulse options
Code:
input_device_index = 2
output_device_index = 2
Perhaps I am not setting up pulse audio correctly?
I installed tightvncserver to run the xwindows because i dont have a usb hub at the moment.
I dont think I actually had to do anything in 'pavucontrol', on the input tab the only microphone on the system was selected. (cheap usb audio device)
Could there still be a missing dependency? There is a lot of "No such file or directory" errors
VA7DMZ
aaknitt 03-19-2013 7:56 AM
Code:
Longtone1
Code:
Code:
VA7DMZ
Thanks for the feedback. I thought I had to install pulseaudio the first time I went through this, but on my second attempt from a new SD card it seemed to already be there for some reason, so I didn't include that in the instructions. I'll add it.
Something strange I've noticed is that when I run LevelMeter for the first time, the pulse audio devices show up as index 2, but after that, they show up as index 3. So you may want to try running it again and/or setting the input and output device indices to 3 and see what that does for you. I get all of those ALSA errors also, but it still works.
Another error it's throwing is that it doesn't see the control_scanner parameter in the config.cfg file, which is because I removed all of the scanner control stuff from v59 and removed that parameter from the config.cfg file that I included in the tarball. However, I forgot to remove the code that looks for that parameter in the program. To get rid of that error you can just add control_scanner = 0 to your config.cfg file. I don't think it will help with the audio issues, but it will at least make that particular error go away.
VA7DMZ 03-19-2013 3:59 PM
OK I started from the beginning again and noticed a few other things.
The URL for pip is wrong for me.
The URL says
Code:
curl ľO https://pypi.python.org/packages/source/p/pi/pip-1.3.1.tar.gz
But I think it should be
Code:
curl ľO https://pypi.python.org/packages/source/p/pip/pip-1.3.1.tar.gz
Also pyserial seems to be needed or else I get this error:
Code:
  File "TwoToneDetect59Pi.py", line 36, in <module>
ImportError: No module named serial
So this is needed
Code:
sudo pip install pyserial
Anyway now I find I have this error.
Code:
ALSA lib pcm_direct.c:877:(snd1_pcm_direct_initialize_slave) slave plugin does not support mmap interleaved or mmap noninterleaved access
ALSA lib pcm_dmix.c:1030:(snd_pcm_dmix_open) unable to initialize slave
Longtone1
defaultdict(<type 'list'>, {'Long Tone Page': array([ 604.,  604.,  604.,  604.,  604.,  604.,  604.,  604.,  604.,  604.])})
I still dont see what I need to do in Xwindows with the PA volume control. Everything seems to set up already.
Do you have more details on what needs to be done in the volume control?
aaknitt 03-19-2013 9:52 PM
Fixed, thanks.
I just uploaded a new version that's been fixed to not require pyserial.
Code:
Try running with the new version I uploaded and let me know if you're still having issues.
Andy
VA7DMZ 03-19-2013 11:59 PM
I grabbed the new version.
It is running now. :)
So I played a recording of my tone into the 'mic in' of my usb sound card, and tried to test it out.
Here it is with amr_emails set up. It didnt work for me. No email was sent.
TwoToneDetect59Pi.pyc - Pastebin.com
It works for me with mp3_emails. This email was sent and I received it with the recording.
Edit: Ive done further checking into the mp3 functionality and it does work once. I cannot get it to work a second time unless i stop the program and start it again. tones.cfg has this entry: 'ignore_after = 60' but I waited long after that to play my tone a second time. Am I screwing it up?
aaknitt 03-20-2013 12:56 PM
Ah, you found a bug. The ignore_after code is using a reference to the GUI, which is no longer there, so it won't work. It's telling the program to ignore that tone after receiving it once but then is never able to tell it start looking for it again because of the bug. Until the bug is fixed, either remove the ignore_after parameter from your tones or set it to -1.
I'll have to look into the AMR issue. Shame on me I never tested it, I only tested mp3. It appears to be an issue with ffmpeg, so I'll have to dig into that a bit.
Andy
aaknitt 03-20-2013 9:55 PM
Andy
Ok I just uploaded a new version that corrects the ignore_after bug, and also some bugs with the AMR conversion. To get the AMR conversion working, you'll need to use the new version and also do this:
Code:
sudo apt-get install ffmpeg libavcodec-extra-53
Instead of what I had on the page before:
Code:
ffmpeg needs some extra codecs installed to work with AMR.
Regards,
Andy
DC31 03-22-2013 4:44 AM
Originally Posted by aaknitt (Post 1936210)
Hi everyone,
Regards,
Andy
That's great news, Andy! I will set up my pi over the weekend and will start some testing. I am a little late on this one as i had only been following the other TTD thread.
DC31 03-22-2013 4:50 AM
Hi everyone,
Regards,
Andy
One quick question that comes to mind:
Can the pi version be set up to retrieve the tones.cfg info from a remote file such as from a dropbox acct? That could help to eliminate the need to ssh into the pi to make changes.
aaknitt 03-22-2013 1:05 PM
Yes it has the same remote tone.cfg capability as the regular v59.
Andy
DC31 03-22-2013 2:59 PM
Okay, Andy, I got a chance to fire it up. I had a few difficulties making the installation work but I got past all of them. Will send you a separate note on these.
I am now stuck at the LevelMeter.pyc point. My device numbers are 3 but when I put that number in all that it returns is zeros regardless of whether there is audio feeding in or not. When I do the pavucontrol the bar indicates that it is receiving the audio under the input Microphone.
Input Device 1: C-Media USB Headphone Set: USB Audio (hw:1,0)
Output Device 1: C-Media USB Headphone Set: USB Audio (hw:1,0)
Output Device 2: sysdefault
Input Device 3: pulse
Output Device 3: pulse
Output Device 4: mmap0
Output Device 5: default
Enter input device index: 3
Enter output device index: 3
(Several lines deleted)
ALSA lib pcm_direct.c:877:(snd1_pcm_direct_initialize_slave ) slave plugin does not support mmap interleaved or mmap noninterleaved access
^CTraceback (most recent call last):
File "LevelMeter.py", line 103, in <module>
File "LevelMeter.py", line 93, in record
File "/usr/lib/pymodules/python2.7/pyaudio.py", line 564, in read
return pa.read_stream(self._stream, num_frames)
KeyboardInterrupt
Any suggestions on where to go from here?
Jim
aaknitt 03-22-2013 3:07 PM
KeyboardInterrupt
Jim
I do remember running in to this, but can't remember what i did to get it working. Is your USB sound card plugged into a hub or directly into the Pi? I had some issues with my hub and had to plug it straight in to get it working.
Andy
DC31 03-22-2013 6:28 PM
Andy
yes, it is in a hub. I had power supply issues with the Pi so I put everything into a powered hub. Will try it direct. Thanks
DC31 03-22-2013 8:11 PM
Plugging it in drect didn't seem to help. But then i went into the pavucontrol again and under the configuration tab turned the ALSA profile to off. So my usb sound card has the profile Analog stereo Output + Analog stereo Input and he ALSA profie is off. This changed the zeros to numbers in the LevelMeter. And then yes i successfully detected a tone and sent emails. I am beat for now. Will work on it more over the weekend and next week.
aaknitt 03-22-2013 10:48 PM
Originally Posted by DC31 (Post 1939082)
I am beat for now
I hear ya. Linux will do that to you :wink:
DC31 03-23-2013 5:43 PM
Global name 'stream' not defined
Andy, I am getting this error regularly when TwoToneDetect59pi is launched. Not every time but probably 50% of the time. I see in post #7 above you indicated that you fixed this error. I downloaded the program yesterday morning (22-Mar) well after that.
Expression 'parameters->channelCount <= maxChans' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1438
Expression 'ValidateParameters( inputParameters, hostApi, StreamDirection_In )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2742
File "/usr/lib/pymodules/python2.7/pyaudio.py", line 714, in open
stream = Stream(self, *args, **kwargs)
IOError: [Errno Invalid number of channels] -9998
File "TwoToneDetect59Pi.py", line 683, in <module>
File "TwoToneDetect59Pi.py", line 672, in record
pi@raspberrypi ~/TTD59/dist $
Sometimes rebooting the pi is all it takes to get it working but just now I rebooted and I still get the error. This error prevents loading the program.
Jim
aaknitt 03-23-2013 8:47 PM
Jim
That's actually a slightly different error than the one above. I suspect this may have to do with whatever causes "pulse" to show up as index 2 sometimes and index 3 other times. I think it may be index 2 but when TTD tries to use index 3 it throws this error. The next time you run the program it's back to index 3, for whatever reason. If it does it repeatedly, try running LevelMeter.pyc and see if the index of the "pulse" devices has changed.
Andy
