What do you use to recored audio off of your scanner? I have a uniden BC125at
RadioGuy3007 Member Database Admin Joined Jan 27, 2013 Messages 316 Mar 21, 2013 #1 What do you use to recored audio off of your scanner? I have a uniden BC125at
pb_lonny Member Joined Jul 2, 2012 Messages 1,916 Location Tasmania Mar 21, 2013 #2 I use Scarec. Download Scanner Recorder (Scanrec) 1.9 Free - An audio recorder that is primarily designed to record speech. - Softpedia
mikegilbert MHz so good Joined Sep 7, 2004 Messages 467 Location Los Angeles Mar 22, 2013 #3 Scan Recorder- It has built-in threshold recording and it's free. When I'm on the road, I use my iPhone with a custom cable made by kV Connection: iPhone 1/8 inch line-level audio input adapter - 3.5mm 4 conductor TRRS Male to 3.5mm TRS Microphone Input Jack with built-in Attenuator
Jimru Member Premium Subscriber Joined Dec 19, 2002 Messages 1,305 Location Henrico County, VA Mar 22, 2013 #4 Scanner Recorder is a great little program, indeed! These guys got it right on!
majoco Stirrer Joined Dec 25, 2008 Messages 4,285 Location New Zealand Mar 22, 2013 #5 ...and if you have a shortwave receiver too, you can feed one track with scanner audio and the other track with the WWV time signal on 10 or 15MHz - then you know what time you intercepted the signal!
pro106import Member Premium Subscriber Joined Dec 13, 2008 Messages 2,858 Location Milford, Ct. perched high above Long Island Sound Mar 22, 2013 #6 Freescan and IDTracker are also 2 very good options.
V vans113 Member Premium Subscriber Joined Jul 10, 2012 Messages 418 Location Tennessee Mar 22, 2013 #7 i use audacity
RadioGuy3007 Member Database Admin Joined Jan 27, 2013 Messages 316 Mar 23, 2013 #8 Audio Recording What would you recommend I should use to record audio if I have a Uniden BC125at
pb_lonny Member Joined Jul 2, 2012 Messages 1,916 Location Tasmania Mar 23, 2013 #9 I use Scan Recorder.
majoco Stirrer Joined Dec 25, 2008 Messages 4,285 Location New Zealand Mar 23, 2013 #10 .....and so do many other scanners too.....
NWI_Scanner_Guy SCANNING THE AIRWAVES SINCE 1987 Joined Jan 23, 2008 Messages 2,298 Location Hammond, IN Mar 24, 2013 #11 vans113 said: i use audacity Click to expand... Same here. At least when I'm recording from my PRO-163 or BC346XT. When using my PSR-800, I use its own built-in recorder function.
flythunderbird Member Feed Provider Joined Oct 1, 2012 Messages 988 Location Grid square EM99fh Mar 25, 2013 #12 vans113 said: i use audacity Click to expand... I do, too. It works great with my PRO-197.
