Just tried it on Win7 x64 with the latest version of Chrome x64. It began having trouble, giving the purple "He's dead, Jim!" error screen when unloading the page to try to navigate to another link. After a few tries, browser navigation failed completely - Chrome was still running and could be closed, but the page was 'dead' - the mouse would not turn into a hand when rolling over hyperlinks, etc. The browser process had to be completely killed to regain control - even other tabs (which you could still navigate to) were dead.
Manually navigating to a new page by typing in the address bar or using bookmarks does not cause the problem. Clicking on a link which opens in a new tab or window (like the FB/Twitter/G+ links in the upper right) does not cause the problem. Only clicks which cause the active window/tab to change, "unloading" the page, cause the failure.
Does the page work properly without the feed applet? Try removing it completely from your page and see if that works.
EDIT: It happens on my page (see my signature) as well, when the player is running. If the player is stopped, it doesn't fail. Tried the same on your page and I can't get it to crash if I stop the feed before clicking a link/refreshing. I would suggest the web player is buggy. Do you see the popup that warns that the audio feed has stopped responding? I get that briefly when I click thru or refresh, when I don't shut off the feed first.
