so I installed Two Tone on a XP box and have everything setup as per the instructions and have gone over it over and over again and still wont send anything to my gmail account. I have gone thru the threads hoping to find a solution. Any thoughts or help would be greatly appreciated.
This is what is in the log file:
Station 180 Tone Set Found
delay timer Station 180 19:24:36 on 11/04/14
delay done Station 180 19:24:37 on 11/04/14
waiting for audio Station 180 19:24:37 on 11/04/14
threshold value: 4096.0
mono
1118.0 6948.99623544
1123.0 6931.20409284
threshold exceeded
recording audio Station 180 19:24:37 on 11/04/14
1123.0 7018.17448991
1123.0 7214.95476789
1118.0 6846.66084121
1118.0 7134.71202966
1123.0 7103.61058364
1118.0 7104.64530661
1123.0 7252.99607075
1118.0 6991.93648734
1118.0 6482.26805098
1118.0 7017.80309193
1123.0 6938.89886488
1113.0 1399.01226502
1156.0 6268.05080787
1242.0 4305.93257349
1274.0 1915.22045983
1290.0 1728.84548815
Waiting for Silence Station 180 19:25:05 on 11/04/14
527.0 17962.5050404
Done recording Station 180 19:25:08 on 11/04/14
done writing WAV Station 180 19:25:08 on 11/04/14
ffmpeg not found, sending as WAV file instead of mp3
File "<string>", line 498, in mail
File "C:\Users\Deer Creek Fire Dept\Google Drive\Python\build\pyi.win32\TwoToneDetect65c\outPYZ1.pyz/smtplib", line 604, in login
SMTPAuthenticationError: (534, '5.7.14 <https://accounts.google.com/ContinueSignIn?sarp=1&scc=1&plt=AKgnsbtjO\n5.7.14 2x6kcDIFVsyet7pbQhlsY3kCPke85BtKRgDVzOq6exXQBxX1xwFHCtdhoK43stySUPrU3Y\n5.7.14 1c28VHVLHtIjgHTn2TGT2ema3K34NBSoo4fsHgRqy544O1ko5MhZIt59qLuDmA6VIdS_rP\n5.7.14 vMHUDv0qi8IGsl3pd92Sym261Y0crlpQMiCwhSvZZ60C6vk9IiqRffaEGdN8WrLFHZo0KY\n5.7.14 -t4CxQg> Please log in via your web browser and then try again.\n5.7.14 Learn more at\n5.7.14 https://support.google.com/mail/bin/answer.py?answer=78754 l6sm1676625pdr.39 - gsmtp')
Email not sent on attempt 1trying again in five seconds for Station 180 page received at 19:25:08 on 11/04/14
SMTPAuthenticationError: (534, '5.7.14 <https://accounts.google.com/ContinueSignIn?sarp=1&scc=1&plt=AKgnsbuTN\n5.7.14 U9TCTX_NqnKd4AwSO2zceng547CGdjChh0armYFt7MKc3ZtOhdL7LDjq-QAjvhX04pzi8t\n5.7.14 5s-HTFAz6UdYsFY3futTpl1x-T2AxZt58nimkVZ4kyOcyLW_9VceXiyNkgYqiXGWal8nUV\n5.7.14 6UMKPCrCl2n7MnTg0OlC5YhxJ4MQmJ9JgioS5GS2HnaeF7fyxWWqb_5H5qNsOkvMwZVmnH\n5.7.14 uW_StSA> Please log in via your web browser and then try again.\n5.7.14 Learn more at\n5.7.14 https://support.google.com/mail/bin/answer.py?answer=78754 ft2sm1707531pbb.15 - gsmtp')
Email not sent on attempt 2trying again in five seconds for Station 180 page received at 19:25:08 on 11/04/14
SMTPAuthenticationError: (534, '5.7.14 <https://accounts.google.com/ContinueSignIn?sarp=1&scc=1&plt=AKgnsbtBS\n5.7.14 J_3u1nvNDvtnGnV0TsjPoTy0nvHNL41jV6bPkRJc9se1nJPOZfJHoKV4huFJ7-VXV2K3Sm\n5.7.14 6e8T2qP6u90dZl6vW6Cwvd-nFzFy4uPX0j1OtRxVRP_uLjcnxxkLmeXJcdDwx5i5Skehnn\n5.7.14 6FNuXpuV25YsRodZCrG5YHIzlizUHLssFeBBlZ_r2YjLNOgnWVYGZtWZkcLwAuCSmIYo86\n5.7.14 UU5rExQ> Please log in via your web browser and then try again.\n5.7.14 Learn more at\n5.7.14 https://support.google.com/mail/bin/answer.py?answer=78754 mi8sm1603958pdb.91 - gsmtp')
Email not sent on attempt 3trying again in five seconds for Station 180 page received at 19:25:08 on 11/04/14
max retries exceeded, failed to send email
This is what the config file looks like:
[Section1]
email_user = kb6bhb@gmail.com ;user id to log in to email account used for sending emails
email_pwd = xxxxxx= ;password to log into email account used for sending emails encoded in base64
email_server = smtp.gmail.com ;SMTP server address of email provider
email_port = 587 ;port to access email server with
record_seconds = 60 ;number of seconds of audio to record after a valid tone set is found
record_delay = 6 ;number of seconds to wait after a tone set is found before starting to record
tone_tolerance = 0.02 ;tolerance of tone detection algorithm 1% = .01
input_device_index = 0 ;index of audio input device
output_device_index = 4 ;index of audio output device
audio_threshold = 54 ;threshold of audio squelch. audio signals below this level will be ignored
tone_offset = 0.0 ;tone offset in percentage. .01 = +1% tone offset, -.02 = -2% tone offset, etc.
mp3_bitrate = 32000 ;bit rate of mp3 encoder. Lower bitrate = smaller file size and lower audio quality
BCC = 0 ;1 = email addresses will be BCC'ed (hidden from other recipients). 0 = recipients will see other recipients
email_priority = 2 ;priority of email (1=highest, 3=normal, 5=lowest)
release_time=3.0 ;amount of silence (in seconds) required before recording will stop (max=60 seconds)
email_from = kb6bhb@gmail.com
update_interval = 60
audio_channel = mono
mono
threshold exceeded
527.0 17962.5050404
[Section1]
