Just downloaded TwoToneDetect today. Toneseditor has been set up and saved.
When trying to open the TwoToneDetect program, I get the following error:
Audio Device Error
"No audio output devices found. If using on board sound card, try plugging an audio cable into the input and output." I press ok and the next following message appears:
TwoToneDetect had trouble finding or accessing an audio device on your system. You may need to plug a speaker and/or line input into your PC in order for the system to activate the audio device. TwoToneDetect will now exit." I press ok and it exits.
The wierd thing is I am running Proscan and the scanner is plugged into the line in on the back of computer and it runs just fine. What should I do?
Jeff
Audio Device Error
Jeff
