If the audio is silent I would make sure you have Trunking Recorder setup to record from the correct sound card. If you are using DSD then it would be the output device you have DSD setup to output audio to. Typically it's one of the virtual audio cable line in devices.
See
Trunking Recorder - Recording audio from trunked radio systems monitored by Unitrunker
I have read the install but have a question.
I am running unitrunker with 2 dongles. I monitor a mixed mot type 2 system with p25. My voice receiver has audio piped to sound card. It has digital piped to vbcable.
When I try to set up recording, the only option in the drop box is vbcable.
Ok. When I start trunking recorder, its showing all calls being logged however there is no audio. I set trunking recorders output to my speakers. All the calls show how many seconds the call was. When clicking on any of them, there is no sound. I went over all my sound settings and everything is good. I get good audio out of chrome and I E.
I then shut everything down and set unitrunkers voice to output analog and digital to my sound card and started trunking recorder again. Same thing, only choice in drop down is vbcable.
Now I added a second vco in unitrunker. 1 is set to pipe analog to sound card, and the other is set to pipe digital audio to vbcable.
Right now I have no active digital.
How do I get my sound card to show up in the drop box? Tried on 1.9 and now using 1.10 beta. I also went to apps data local bla bla bla and deleted all files to reset trunking recorder..
