KJ6HCB
Hey everyone - just picked up an HP T5730W Thin Client. Ive seen others use this model so Im pretty sure it should work for an RR stream.
I understand that the system needs the proper operating system, this may be my first problem. From what I can tell it is running Windows Standard Embedded. Will I be able to use that, or does Windows XP, or XPEmbedded need to be installed on the unit? If so, how do I go about that?
Next, I understand the EWF or some sort of write filter needs to be turned off on the HD, through software I presume. How do I do that? Then Ive read .NET 2.0 or higher framework needs to go on, then ProScan can go on.
I seem to be stuck at a few of the earlier steps, Im thinking Windows Embedded Standard wont work for the OS. Can anyone help?
