Is there anyone else using ProScan version 10.1 web server? If so can you confirm these issues?
The scanner display window position is incorrect and does not update. The scanner control doesn’t work either. This has been confirmed with multiple browsers on multiple workstations. Screenshots are attached showing difference between 10.0 and 10.1. Please feel free to see for yourself at:
http://scannerfeed.asuscomm.com:5333
All other versions appear and function fine.
Thanks!
Thanks!
