RadioFeed Software
ProScan
Software Provider
Ontario, Calif.
RadioFeed Version 3.6 Release 04/17/16
  • Added - Web Server - HTML5 audio player embedded in web page.
  • Added - Audio - MP3 Bitrates of 56, 64, 80, 96.
  • Added - Broadcast Lockout file for the Web Server & Source Client now can specify system for TGID lookup.
  • Added - Button to view the application and data folders located in the Test & Extras tab.
  • Added - Custom Specifier "%U2 = UID After Lookup".
  • Changed - Custom Specifier "%U = UID" changed to "%U1 = UID Before Lookup".
Text Tags supported for the BCT8, BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BC898T, BCD996T, BCD996XT, BCD996P2, HomePatrol, PRO18, PRO106, PRO107, PRO197, PRO652, PRO668, PRO2052, PSR310, PSR410, PSR500, PSR600, PSR800, WS1040, WS1065, & WS1080 scanners.
RadioFeed and ProScan are the most powerful and feature rich scanner streamer software in this world.
RadioFeed Setup Instructions - The RadioReference Wiki
Deziel0495
PE/NB Database Guy
PEI
Can you explain the difference between the two UID options? I'm not sure I quite understand.
M105
I downloaded the 3.6 version and have run into an issue. I am using just the web server and I have the feed password protected. When I use the standard player everything works as it always has and the stream plays fine. When I try to use the HTML5 player built into the web page, Internet Explorer returns INVALID SOURCE. Chrome simply sits there with a grayed out pause button.
If I go to the RadioFeed web server setup and remove the password requirement for serving the audio stream the HTML5 player will then work as it should. Put the password requirement back in and it returns Invalid Source again.
Is there some other setting I am missing to make the HTML5 player work when a password is required?
Deziel0495
PE/NB Database Guy
PEI
Kind of experiencing the same thing, but on my phone. Local connection works perfectly both on my phone and PC, but when I try to connect "outside" on my phone, when I press the play button it either grays out the player or nothing happens and it sits at 0:00. I get no audio from either one.
Both my phone and PC use Google Chrome.
Also, another thing I noticed... Once you select a file or folder to be "served", there is no way to delete it or uncheck it.
M105
Thanks for the confirm. I was beginning to think it was just my system. Mine acts the same whether I access it from the local network or over the web.
rjdj2000
Gone Cuckoo
Central NY
Bob,
Love the program but was wondering if somehow can get it so we can designate a lockout file for each side. Say lockout1.txt for the source client and lockout2.txt for the web server instead of having 1 file for both?
ProScan
Software Provider
Ontario, Calif.
RadioFeed Version 3.7
RadioFeed Version 3.7 Release 05/17/16
  • Added - Web Server - Option to always serve the Stream Description box or only serve when logged in with the audio stream password.
  • Added - %H Custom Formatter 24 hour format.
  • Added - Web Server - Clear Serve Folder Location button.
  • Changed - Web Server - Password Logic. See the RadioFeed Setup Instructions "Web Server Password Logic" section for an explanation.
  • Fixed - Web Server - HTML Audio Player wasn't working if audio stream password protected.
M105
Works great now. Thanks ProScan for the excellent software!
ProScan
Software Provider
Ontario, Calif.
RadioFeed Version 3.9 Release 10/18/16
  • Added - Color Options - Now with more colors.
  • Added - Source Client and Web Server Metadata now has a 'Remove From Metadata' text option.
  • Fixed - Frequency in the Web Server and Source Client Metadata wasn't showing when using Uniden DMA scanners.
  • Fixed - Web Server - Using built in HTML5 Audio Player was causing erroneous Client Connections grid entries.
  • Fixed - BCD536HP WiFi audio automatic restart wasn't working.
ProScan
Software Provider
Ontario, Calif.
RadioFeed Version 4.0
What's New
  • Added - Separate Broadcast Lockout files for the Source Client and Web Server features.
  • Added - BCD536HP and BCD436HP option to display trunking system names.
  • Added - Web Server Metadata Delay option on the web page.
  • Changed - Web Server Update Interval option moved to the web page.
  • Fixed - Metadata Frequency wasn't showing when the scanner type set to BCDx36HP scanners.
rjdj2000
Gone Cuckoo
Central NY
Thanks for including the separate lockout files in this version. As I said before, it helped me out tremendously. I can now serve both web and source using my 536HP and can have the required items locked out on the source side with everything being open on the web side. It has been running flawlessly since we worked on it awhile back. Will go ahead and do a full update now. Your software is the best Bob!!
ProScan
Software Provider
Ontario, Calif.
You're very welcome.
I think so too.
I never explained this one. This option will delay the Metadata Text Tags shown on the Web Page to compensate for the various media players latency buffer. If the media player delays the audio X amount of time, then setting the Metadata delay to the same X amount of time will show the Metadata in sync.
ScottPDX
Portland,OR
RadioFeed Rocks!
Hello Bob,
I just want to say thanks to you for creating and supporting RadioFeed. I discovered RadioFeed in the last 2 months and love it. I also like the latest enhancements you have made to 4.0.
ScottPDX
M105
RadioFeed Version 4.00 positioning issue
If this has been mentioned before accept my apologies but I just downloaded version 4.00 and started using it. I notice what appears to be a CSS positioning issue on the web server screen. The drop-down box for Update Interval is covering up the password box.
I am using IE 11 on Windows 10 Pro. Partial screenshot attached.
ProScan
Software Provider
Ontario, Calif.
This will be fixed in the next release of RadioFeed. The last ProScan release fixes this issue. This problem appears on the IE and Edge browsers.
{edit}
Put this in the style1.css file for a normal size audio player. Refresh the browser afterwards with the F-5 key.
Code:
#audio_player {
    width: 320px;
    height: 32px;
M105
Thanks for the reply. I will DL the update when available. The media player looks better in the smaller size too!
