I have a BCD996XT and I don't have 2nd scanner yet. My computer is
HP Pavilion Media Center m8430f
* I record from the front, Can I record with the 2nd scanner on the same sound? Or do I need a 2nd sound card?
I use the factory sound card with a stereo plug split into mono left and right for scanner 1 L scanner 2 R and 2 USB sound cards like the one you listed I just use a different brand 1 for scanner 3 and 1 for scanner 4 most USB sound card have mono mike inputs is the reason I use 2.
These are what I am using but others here have used others just fine.
USB2 0 External 7 1 Channel 3D Virtual Audio Sound Card Adapter PC | eBay
You can setup PROSCAN multiple times 1 for scanner 1 rename 2 to a different name and run it for scanner 2 left audio goes to scanner 1 and right audio goes to scanner 2 is the way I set mine up for the main sound card line in. Then for scanner 3 to USB 1 and scanner 4 to USB 2 and then work on setting your levels.
Q: Can I run multiple copies of ProScan or RadioFeed on one computer?
A: Yes. Many instances of ProScan or RadioFeed can run on the same computer. Copy the contents of the ProScan or RadioFeed folder to a new folder. Change the comm. port setting and other options specific to that instance.
So the sound card would this work? http://www.amazon.com/external-Adap...65133749&sr=8-2&keywords=sound+card+line+jack
Would this wire work to plug into the USB? Amazon.com: Amp Powers 3.5mm 1/8 male mini plug to male mini plug monaural mono audio cable 2 Pack: Electronics
Yep.
Are the audio cables running beside each other, if so seperate them for their entire runs.
