Online scanner w/ more than one freq
2Dis
Hello,
For online scanners with more than one frequency being monitored, is it possible to have only certain ones play? Or is that up to the broadcaster to do with their own scanner?
Thank you.
motomeso
Ontario
If you scanner has a "record output" you can flag what talkgroups and channels get recorded into the scanner and use that port to feed the computer soundcard.
2Dis
Thank you, Mike.
I meant a Broadcastify feed. Thanks for the answer!
If the feed says it is scanning multiple frequencies... could there be any reason why I can't hear one of them exactly?
eaf1956
Evansville, IN
Hello,
Thank you.
If you are the listener you can only listen to what is put out on the feed. You can't select certain things as a listener.
