Old 05-12-2017, 11:18 PM
pkneeyahx's Avatar
Default proscan - custom filename formatting
was there a change recently in a proscan update tot he custom filename formatting for recordings? I can't seem to get 24 hour time on my filenames. Its inserting AM / PM, which sucks for sorting files by filename in winamp, etc.
here is an example of what i'm looking to implement;
03-26-17 22-17-44 - Kinburn - 2OPS01 Arnprior.mp3
And when I try to use the %H formatter, it literally just uses the hour. not the entire 24 hour timestamp.
thanks!
Sangean ATS-803A / Realistic Pro-2006 / BCD436HP / BCD996P2
Old 05-13-2017, 6:02 AM
ProScan's Avatar
That's how the "%H" is suppose to work. &H = Hour (24)
What Custom Formatter are you using to give AM / PM. "%DT"? Checking the "24 Hour Time" option should do it.
{edit} Use this "%D %TT" for the desired results.
Old 05-13-2017, 7:36 AM
pkneeyahx's Avatar
%DT - %S - %G - %C is what is giving me AM and PM. I will try as you suggest.
Old 05-13-2017, 7:42 AM
pkneeyahx's Avatar
I must have missed the "24 Hour Time" check box under the Options/General tab. I'll let you know how that works once the clock rolls over to 1300.
Old 05-13-2017, 9:00 AM
pkneeyahx's Avatar
Hey, thanks for reminding me about the 24 hour time check box. Its working.
05-13-17 - 09-56-38 - Kinburn - OPP Combined - 2OPS42 Renfrew.mp3
