Help setting up Raspberry Pi RTL-SDR Feed
freema22
Michigan
Hi team,
I am a novice when it comes to my Raspberry Pi. I currently provide ADS-B coverage to ADSBExchange.com and FlightAware. I have a 2nd SDR that I would like to use to provide a feed to Broadcastify. I have tried following the information on the Wiki (wiki.radioreference.com/index.php/Raspberry_Pi_RTL-SDR_Broadcastify but once I get to the "sudo make install" step, I get a "file INSTALL cannont find '/home/pi/rtl-sdr/rtl-sdr.rules" error and everything stops.
Can anyone post (or PM) me the commands that I need to execute to get my Pi up and running for Broadcastify?
Thanks,
csmith00
NJ
Hi team,
Thanks,
Instructions appears to work for me(see attachment). Are you sure you did not skip a step?
  • rtl-sdr_build_session.txt
