Pi3 Broadcastify Image
fdnyfish
Barnesville, PA
I got my first Pi machine yesterday (never touched one before), after 3 hours I scratched the idea of using the RTL-SDR, could not get it to work following the WIKI word for word.
Started over using the USB sound card and got it working my first try (after finding this thread).
I am just waiting for my cheap scanner WS1025 to get here Saturday, as I don't want to dedicate my WS1098 for just 1 analog channel stream.
JACK26
Milpitas, CA
If you're using this wikilink:
Raspberry Pi RTL-SDR Broadcastify - The RadioReference Wiki
It doesn't work word for word (the last time I tried anyway),
Replace the instructions for installing the rtl-sdr software from osmocom with:
git clone https://github.com/keenerd/rtl-sdr/
It took me many months to get it working well the first time. It takes a lot of patience and tweaking for each setup.
My feeds are here (2 rtl-sdr's on a single rpi3):
https://www.broadcastify.com/listen/feed/23831
https://www.broadcastify.com/listen/feed/25781
If interested, code is here (rtl_fm command is in start1.sh and start2.sh. See readne,txt)
https://goo.gl/9p1oZJ
Using debian pixel on rpi3.
Never tried the downloadable image.
fdnyfish
Barnesville, PA
So my only remaking question is,....
Is there any way to see a visual on the pi device that the stream is active?
Maybe a window with stream uptime or something?
DC31
Massachusetts
If you are providing a BCFY feed, just set yourself up for FEED DOWN alerts and trust that if you don’t get one that all is fine. My experience with darkice is that it is VERY reliable. The majority of the downtime cones from ISP interruptions.
No, I don’t know of a good visual means of confirming operation. At the command line you can type top and that will return a list of running processes, one of which should be darkice.
There is a companion program called darksnow which is a GUI interface to darkice, but I have found it troublesome.
https://forums.radioreference.com/s...ing-raspberry-pi3-using-darkice-darksnow.html
