Old 12-23-2017, 11:47 AM
fdnyfish's Avatar
Default Darkice won't auto start on boot
I followed the instructions of this wiki
https://wiki.radioreference.com/inde...the_Sound_Card
but when i boot up my raspberry Pi3 and run the "top" command, darkice is not running.
If I send a "sudo service darkice1 start" the service still does not start.
The only way I am able to get darkice to manually start is by sending the following 2 command, then I see darkice running when used the "top" command.
sudo service darkice1 stop
I even added both commands to my "/etc/rc.local" file right before the exit 0 but that don't work either.
Can I get some help please.
Retired FDNY*EMS Captain
KB2MXV
Old 12-24-2017, 8:14 AM
fdnyfish's Avatar
Default active (exited)
active (exited) is the status of the service when checked
pi@raspberrypi:~ $ service darkice1 status
● darkice1.service - LSB: Simple script to start a program at boot
Loaded: loaded (/etc/init.d/darkice1; generated; vendor preset: enabled)
Active: active (exited) since Sun 2017-12-24 19:10:22 +05; 2min 40s ago
Docs: man:systemd-sysv-generator(8)
Process: 367 ExecStart=/etc/init.d/darkice1 start (code=exited, status=0/SUCCE
CGroup: /system.slice/darkice1.service
Dec 24 19:10:22 raspberrypi systemd[1]: Starting LSB: Simple script to start a p
Dec 24 19:10:22 raspberrypi darkice1[367]: Starting darkice Instance #1
Dec 24 19:10:22 raspberrypi systemd[1]: Started LSB: Simple script to start a pr
KB2MXV
Old 12-24-2017, 8:38 AM
fdnyfish's Avatar
I have it working. Here is what I did.
sudo update-rc.d -f darkice1 remove
crontab -e
@reboot sleep 30 && sudo service darkice1 start
KB2MXV
