Need help setting up 2nd feed
shajoe44
North Augusta, SC
I am trying to set up a 2nd feed. I am using 2 scanners and going thru primary sound card and 2nd scanner is going thru usb soundcard. I have 2 scannercast windows open. One for each feed. It was working yesterday but today scanner #2 was being broadcast over both feeds. I looked at setup on scannercast and nothing had changed. Scanner one still showed primary sound card and scanner 2 showed usb soundcard. Any help will be appreciated. Also I need to found out how to broadcast talkgroups with 2nd scanner which is a WS 1065. First scanner is broadcasting conv channels for local fire and police. 2nd scanner is broadcasting a digital P25 talkgroup.
