Joshheartbrake
- Joined
- Apr 7, 2018
- Messages
- 136
i need help please, i have proscan and am running the webserver and have opened a port (5001) on my router to my local ip( desktop computer) . i double checked if it worked by using my laptop and i typed my local ip address, following the colon ,and the port number (5001) in my url , and my stream came up pefectly fine ...... but whenever i try to open the port using my external ip adress it does not work , it even used the checkmyport.com website or whatever to test if my port is working externally and it says connection timed out!
i can only connect the port through my local ip adress , how do i open the port with my external ip adress so when im out of town i can view my stream on a different network ??????
