Old 06-18-2018, 11:08 AM
Default PROSCAN - Broadcast Lockout file
I thought I was blocking some tac talkgroups but watching it this morning, and playing with the file, it doesn't appear that it's working for me. I've probably got the format incorrect.
This is a BC796 tracking a P25 system (State of Colorado DTRS)
I've opened the file and tried putting in just the Talkgroup number, the TG with the label for the bank, and the TG with the label for the group within the TG database entry.
For testing I used 8100 since it's the busiest, but I'm still hearing the traffic on the stream and never see the Lock out indicator light up.
Computer is a duo core, but running windows XP.
I have it entered a couple of different ways for my testing at the moment. None seem to work.
Have also tried it with only single entry in all of those formats and none seem to work.
# BROADCAST LOCKOUT FILE (SOURCE CLIENT & WEB SERVER)
# Add Frequencies, Talk Group IDs, and Channel Names not to broadcast.
# "SYS=[system name]" Specify a system name on conventional systems or site name on trunking systems if desired to match with system or site. See examples below.
# Text after # pound character are comments.
# EXAMPLES:
# 484.2875 SYS=LAPD
# 4208 SYS=Aerojet
# 0-01-002
# 11Fh SYS=Aerojet
# Ontario PD SYS=Aerojet
154.695
8100
8100 SYS=Sunlight DTRS
8100 SYS=Lookout DTRS
8101 #CSP Tac
8125
8370
8368
Any help appreciated
Chuck
