Help with Darkice - RTL SDR
AB5ID
Lee's Summit, MO (Kansas City)
I have 3 streams coming from RTLSDR -Airband hi going to 3 mount points on a local Icecast server. Can I combine the 3 streams into 1 stream to feed Broadcastify?
Sent from my SM-G955U using Tapatalk
qrplife
Sunny California
This sounds like an interesting application.
Do I understand that you want to combine the streams from 3 Icecast mount points into a single stream, in the same way that an analog mixer would combine three input channels to the master output?
I don't have a solution at hand, but am simply trying to understand the problem.
