The RadioReference.com Forums
-   Streaming / Broadcasting / Audio Recording (https://forums.radioreference.com/streaming-broadcasting-audio-recording/)
-   -   scan feed problems (https://forums.radioreference.com/streaming-broadcasting-audio-recording/376713-scan-feed-problems.html)
kb9gig 09-15-2018 7:54 PM
scan feed problems
when i try to turn on the metadata in the scancast program it gives me an error even though i have the com port and data speed set and i also noticed that it doesn't give me a choice for com port i have to actually enter a number there because it shows none.
the error it gives is OBJECT REFERENCE NOT SET TO AN INSTANCE OF AN OBJECT
it does this anytime i turn on the 996 feed with the metadata turned on what am i doing wrong
W8RMH 09-16-2018 2:05 AM
Give RadioFeed a try. I had a lot of problems with scannercast.
flythunderbird 09-16-2018 11:08 AM
I concur. I also had some issues with ScannrCast. No such issues with RadioFeed.
