I downloaded v70...i set it up....here is my config file:
[Section1]
email_user =
johnsonmitc@yahoo.com ;user id to log in to email account used for sending emails
email_pwd = XXXXX= ;password to log into email account used for sending emails encoded in base64
email_server = smtp.yahoo.com ;SMTP server address of email provider
email_port = 587 ;port to access email server with
record_seconds = 30.0 ;number of seconds of audio to record after a valid tone set is found
record_delay = 6 ;number of seconds to wait after a tone set is found before starting to record
tone_tolerance = 0.02 ;tolerance of tone detection algorithm 1% = .01
input_device_index = 0 ;index of audio input device
output_device_index = 3 ;index of audio output device
audio_threshold = 54 ;threshold of audio squelch. audio signals below this level will be ignored
tone_offset = 0.0 ;tone offset in percentage. .01 = +1% tone offset, -.02 = -2% tone offset, etc.
mp3_bitrate = 32000 ;bit rate of mp3 encoder. Lower bitrate = smaller file size and lower audio quality
BCC = 0 ;1 = email addresses will be BCC'ed (hidden from other recipients). 0 = recipients will see other recipients
email_priority = 3 ;priority of email (1=highest, 3=normal, 5=lowest)
release_time=3.0 ;amount of silence (in seconds) required before recording will stop (max=60 seconds)
audio_channel = mono ;audio channel of sound card to record from. Valid options are 'mono', 'left', or 'right'. Default is 'mono'
email_from =
johnsonmitc@yahoo.com ;email address to show in "From" field. Generally keep the same as email_user to avoid spam flagging
stacked_extend_record = 1 ;Set to 1 to extend recording time and remove stacked tone audio when a stacked page is detected during a recording.
start_minimized = 0 ;Set to 1 to minimize TwoToneDetect to the task bar when it is started.
instance_id = ;Put text here that you want to appear in the title bar of the program
email_security = ssl ;Email security type. Valid values are "none", "STARTTLS", and "SSL"
email_authentication = 1 ;Normally set to 1 to enable email authentication (username & password login). Set to 0 to disable authentication.
email_send_sequential = none ;Send emails one at a time instead of as a group. Valid options are "none" (send to group), "all" (send individual emails), and "Verizon" (send individual emails only to Verizon SMS & MMS addresses)
update_interval = 60
upload_ftp_server =
upload_ftp_port = 21
upload_ftp_username =
upload_ftp_password =
upload_file_prefix =
i get the following error...
class...socket.timeout
timed out
