Would someone be so kind to test this out for me dubbin2.no-ip.info
Dubbin Member Feed Provider Joined Dec 19, 2002 Messages 4,462 Location Findlay Ohio Dec 8, 2006 #1 Would someone be so kind to test this out for me dubbin2.no-ip.info
fmon Silent Key Jan. 14, 2012 Joined May 11, 2002 Messages 7,741 Location Eclipse, Virginia Dec 8, 2006 #2 Loud and clear at 1350 eastern Edit: Ya could turn the gain down a little. Last edited: Dec 8, 2006
Dubbin Member Feed Provider Joined Dec 19, 2002 Messages 4,462 Location Findlay Ohio Dec 8, 2006 #3 fmon said: Loud and clear at 1350 eastern Edit: Ya could turn the gain down a little. Click to expand... A little loud? I just turned it down a bit.
fmon Silent Key Jan. 14, 2012 Joined May 11, 2002 Messages 7,741 Location Eclipse, Virginia Dec 8, 2006 #4 Dubbin said: A little loud? I just turned it down a bit. Click to expand... Putnum, Wood and Allan counties are booming as was Hancock. Keep the setting right where it is now. Findlay is also great. Sounds like you may have just turned it down again. If so this setting is even better.
fmon Silent Key Jan. 14, 2012 Joined May 11, 2002 Messages 7,741 Location Eclipse, Virginia Dec 8, 2006 #5 Gotta run on an errand for a couple of hours.
Dubbin Member Feed Provider Joined Dec 19, 2002 Messages 4,462 Location Findlay Ohio Dec 8, 2006 #6 Thanks for the test Frank. This is just the demo so don't expect it to be running when you get back
