kc8qch
Hello all,
After looking through some of these posts, I put together an aduio/video feed of a pro-96 scanner from the house. At this point, it only runs in Windows Media Player because I am streaming it via Windows Media Encoder.
If you all could do me a favor and see if you can connect to it and tell me what you think? Let me know if you have a problem connectiing, can;t connect at all or anything. Yes I know the audio is Ehhh but it is a facotr of the age of the scanner, the distance from the control channel and I think I have a bad audio cable. But this is just a test at this point (a beta if you will
To connect, you can go to http://www.kc8qch.com/audio3.asx and this will open your media player. or open mieda player manually, click on file and open url and the url is http://www.kc8qch.com:1638.
This is only a temporary feed and will likly be taken down after a day for refinment. Thanks all.
BTW the feed you are listening to is the City of Cincinnati Fire Department, just the Dispatch talkgroup and the Fireground 2 talkgroup.
Jeff
Jeff
