Hello - Would someone be willing to check out my Ingham County EDACS system feed using scaningham.hopto.org. The audio port is 8100 and the data port is 8101.
That is likely your router address, we need your no-ip id or whatever you are using to get out. BTW, you can use this page for a self test. http://www.canyouseeme.org/
Well the IP address I'm connecting to the internet with is 75.14.33.141. The DNS entry is scaningham.hopto.org. I'm not sure if the IP address is supposed to change or not, but I heard I needed to download the no-ip dynamic update client to make sure the most current IP address is used. I thought that if you typed the DNS entry, you wouldn't need to know the IP? Maybe you can fill me in?
