Tweekerbob
- Joined
- May 27, 2004
- Messages
- 614
VERY long story short, it seems that at least with my ATT CallVantage telephone adapter that there is a built in firewall. Unconfigurable and darn near, if not all, ports blocked. I didn't start off bald, but now I almost am, after messing with this thing the majority of the day.
Best advice, plug the TA into an open LAN port on your router (behind the router). It took me all day to figure this out because at the same time I was switching over from cable to DSL, so lots of variables involved.
I don't know if other VOIP services' TAs do this as well; just that I'd post this to save someone from losing their hair!
I can't confirm for sure that there is a built in firewall, but through LOTS of testing, this has to be the case. The internet could not see any one of my computers on any port, even though I turned off my router's firewall! The manual suggests that you run a cable from the modem to the TA and then to the router. Using that configuration led to a explosive level of swearing, and ultimately may have led to the demise of good equipment. Spare yourself some grief and plug the TA in behind the router instead of in front of it.
