2guntom
Under "Greeneville, City of"
the list shows "Light&Power" as 153.665
Greene County, Tennessee (TN) Scanner Frequencies and Radio Frequency Reference
This is incorrect!
The frequency should be 153.650
When you click on "Utilities"
Utilities Scanner Frequencies and Radio Frequency Reference
The input and output frequencies are switched.
Input should be 158.175 (I'm assuming because I have never monitored the input, but...)
I know for certain that the output should be 153.650.
On a side note:
153.500 is correct. That is commonly known as the "E Channel"; it is owned and maintained by GLPS.
The 153.695/158.415 is a new one to me. I will start monitoring it and see what comes up. But with the repeater frequencies mentioned above, I suspect the input/output is switched also.
This is incorrect!
On a side note:
