Northeast part of the state is Wings territory although they are sometimes called down this way if Lifestar is busy.
If you scanner accepts DC tones then you would program 3 453.5000 frequencies with the listed tones. If your scanner does not accept DC tones then you will just program 453.5000 once and it will pickup all of the repeaters if they are in range. If I remember correctly they broadcast some digital data or something because you will hear it without the DC codes programmed in.
The "200" frequency always comes in staticky here. I believe that frequency is a repeater at UT so that is why it is staticky to me. Somebody uses it on occasion but really Im not sure if its Lifestar or someone at the hospital talking to someone else. Never paid much attention to that one because of the signal.
