Phase II TDMA system data on the CC verified by DSD+....
Also new TG found.
TG 3583 with RID of 10008 (TG not in database)
Usage unknown.
Also new TG found.
Usage unknown.
Also new TG found.
Usage unknown.
Milf it may not be none of my business, but can I ask where you get your information at?
I work for the City of Franklin, which has been on P25 800 for many years. Currently Williamson County is installing new towers and equipment to connect to Franklin's existing system. Basically expanding Franklin's system to cover all of Williamson. It will also be tied in to Metro's system. The way it was explained to me is that we will act like fail safes for each other. Then the entire system will be tied into the TVA and TACN stuff.
The latest is that they want the new system up and running by the end of this summer for testing. Motorola Nashville was at the Franklin Fire Stations over the past few weeks removing old radios and installing new radios. They will eventually be installing and issuing new radios to ALL agencies in Williamson County. They must be serious about the system being up and running before the end of the year. I won the contract to remove all the old Knox Box/Sentralok key systems and install new ones on all fire apparatus in the County. The old Knox Box/Sentalok system uses DTMF tones set off by dispatch to release the keys over the VHF analog system. The new radio system obviously will not do DTMF, so all the boxes had to be swapped out.
A lot of places from Motorola folks, to DPS folks, to government employees, relatives in the government and in DPS, press releases, watching FCC licensing, actual monitoring.... And a lot of inside informants that I will not disclose as to keep their jobs, personal information, and other things safe. In multiple States, not just TN. I have made a contact or two over the years in places I have lived, visited, etc. Once you have been involved with scanning, and Public Safety for over 30 years, you build up good sources,.. And sometimes a few bad ones, but the good stuff out ways the bad, and the good sources will usually correct bad info very fast!
The areas around Metro will be using Metro's core. The core will connect to the Chattanooga core. A system of systems.
