frequency
Boulder
Wood County, TX
Champion EMS uses the Teletouch LTR trunked radio system for all their communications. The units in Van Zandt county use the Wills Point tower along with the unit in Emory in Rains county. The Wills Point frequencies can be found here. You will need a scanner that is capable of scanning LTR systems to monitor.
BC_Scan
Vancouver BC
Wow 7 years later ? So if it were me according to what other gent has posted it's not clear what flavour of LTR is in use, put in the freq's for the tower closet to you if you dont know put them all in, and attempt to glean information, even if Passport you could still listen just lock out control channel. LTR regular is easy to learn for a beginner. Good luck
