Ensnared
Recently, I've been visiting in Big Spring, Texas. When I turned on my pre-programmed digital scanner, several frequencies were found to be silent. Hence, I started to search for active tones.
When I opened up the FCC DB for Howard County, I found some interesting frequencies.
ULS License - Public Safety Pool, Conventional License - KNFR291 - HOWARD, COUNTY OF - Frequencies Summary
This call sign showed what I believe to be low power itinerant frequencies. Well, I think that is what you call FX1 & FX2 frequencies. If I'm not mistaken, these are sometimes used as input frequencies, but I'm not sure. I know that some radio setups allow officers to patch to portable radios to their cars. Do these low power frequencies work for this kind of setup?
When I put some of these UHF frequencies into the scanner, I was surprised to find DC:072 for 458.05 mhz. Also, I found 458.25 showing CT:123.0. As expected, I am hearing a simplex transmission on these low power frequencies.
Today, I discovered that Howard County SO Primary is using CT:192.8 like Big Spring Fire/PD. In the recent past, the PD and SO moved into a new communication center/jail. They are sharing services. However, I don't know if they are using different dispatchers sitting in the same communication suite.
I attempted to obtain a channel guide for all LE in this county from an insider. Let's see I get it.
