txscan
Any information about this area is greatly appreciated..I am moving there...are they digital??
So, you are moving to San Angelo? Good luck on scanning because you won't be hearing much from San Angelo PD. If you know how to intercept using a computer, there is still encryption to deal with out there. There is an interesting communications center for the military in the area, but good luck hearing anything. Eventually, you might be able to hear things on the Permian Basin trunking system, but not for San Angelo. But, this is a growing system. San Angelo cops tend to take themselves way too seriously. I've attempted to monitor this city when they were more open in their radio transmissions. Like Big Spring, where my father resides, this is an extremely boring area to monitor. Good luck.
Really? I successfully monitor communications in the San Angelo area quite well every day. With the exception of the base, I've found the database here to be very helpful.
Why so much encryption?
...that would be a bit boring for me since Waco has a much more active scanning environment.
San Angelo is in the process of migrating from EDACS to P25.
Because there is a need for it? Not everyone needs access to the inner workings of the PD. They should be able to conduct operations without the "bad guys" being tipped off and nosy people getting the the way. Not to mention officer safety. IMO, it's kinda like OPSEC.
To each their own. I find it to be enough for the reasons I listen.
So...getting back on topic, I've found the database here to be very helpful. I find there to be enough to listen to for the reasons I listen. YMMV...
Somebody in San Angelo needs to update the Goodfellow AFB trunked system.
They need to find the System ID, WACN, site number, and NAC so we know if it is part of one of the DoD nationwide systems. Also the primary and alternate control channels should be identified.
That means it is really site 118 of this system: United States Air Force (BEE00-3D6) Trunking System, Various, Multi-State - Scanner Frequencies or probably RFSS 1 site 18. I don't think 396/996 scanners display the RFSS and Site numbers properly. Based on your info I submitted this to the database.I have a bcd396xt and monitor this system I show a CC on 138.0375 and a SID of 03D6h-0118.
Laughlin is a mystery. Nothing in the database for it.
Hmmm...I just noticed today that I'm not picking up SAPD any more. I can hear them via Broadcastify, but my scanner is silent. I wonder what I changed...or lost...
ETA: I wonder if this happened when I re-entered the sites as separate listings instead of one massive entry. Seems to only be PD as I can still get FD fine.
