nd5y
Wichita Falls P25 system went off the air at about 3:15 pm.
FD is using 8CALL90.
PD is using 8TAC91.
PD is using 8TAC91.
Using P25 repeater/simulcast for fireground is too dangerous. You guys really should not be doing that. If they want to hear what is going on elsewhere, get a vehicle repeater system or some other way to upload the fireground communications.
https://www.firerescue1.com/fire-pr...n-Houston-firefighters-families-sue-Motorola/
Irony, fireground operates on P25 (conventional and trunking) all over the GATTRS system and they have very few issues with it. I can actually thing of few departments that have analog fireground frequencies (Oakalla VFD is one as they are in the Lampasas/Bell/Burnet tri-county area).
That recommendation was removed several revisions ago. P25 and trunking are OK for fireground per the most recent 1221.NFPA1221 is the standard for fire service radio systems. There is no requirement to follow it, but it's designed to provide optimal communications.
It specifies analog, non trunked communications for operations and analog simplex for fire ground. The later is often ignored.
Why are aircraft still on AM?
Because at this point in time it truly would be an logisitical apocalypse to try to replace millions of radios worldwide. A far worse headache than just the nightmare with going NXDN on the railorads in JUST THE USA... And in military aviation there is mixed usage of analog AM on VHF and UHF, as well as analog, digital, and encryption on FM.... But changes that were called sci fi a few years back are starting to roll out in the aviation comms world... A lot slower than in ground comms, but its happening.
Actually, aircraft still use AM because it doesn't have the "Capture Effect."
https://en.wikipedia.org/wiki/Capture_effect
It's still too big of a chance.
Inside of a burning building is no place for repeaters or digital. I don't care how much work they have done to make digital more reliable, they are still trying to get it up to analog standards for reliability in that environment. Scratchy analog is better than a dead digital signal.
As for firefighters who are not radio people or trained well, I can remember in the good old days of having to remind the IC that we should probably switch to the simplex fireground channel, or at least the simplex output of the dispatch repeater. That was outside, with no obstructions (on the beach) Derp....
The issue with this statement, simplex comms (analog or digital) aren't going to work when you have a large scale structure fire or high acreage brush/forest fire regardless of whether or not it's analog or digital. We're talking guys on the line of a burn where you are measuring the burn in tens of thousands of acres or a 41st story fire on a 50 story building.
That being said, every current generation radio I've tested either performs identically when digital is compared to analog or better when digital is compared to analog (for conventional operations). I've seen some issues where brand A doesn't perform on trunking like brand B but conventional has a fairly level playing field.
How often are most firefighters battling fires covering tens of thousands of acres or 50 story buildings?
In limited times, the IC can decide to use a repeated fireground channel. For most times, conventional should be used. If the tower is three miles away and the IC is 100 feet away, I'd take my chance of the IC hearing me direct.
