I was told the homepatrol 2 would work for the two above counties, but I do not pick anything up..anybody using this or another type of scanner
The HP-2 will work. Since your's, apparently, isn't, it's possibly programmed wrong. Please answer the following, so that we can try to get you on track.I was told the homepatrol 2 would work for the two above counties, but I do not pick anything up..anybody using this or another type of scanner
I'm not in your county; I'm in Dallas, but I have no trouble hearing my local systems with my HP-2. While there is not a large regional trunked system such as TXWARN P25 here in DFW, there are a large number of systems in various modes from analog to P25 Phase I and also P25 Phase II. I have most of the systems in range loaded, and the HP-2 handles them with no problem.I've had scanner over a year, tried all these things over 6 months ago and even sent it back to uniden and was told it should work, but no luck, I'm looking for anyone else using a hp2 and it works or what type they have and does it pick up all the rd and law enforcement in the county
Are you using location control along with your Favorites list for Galveston & Brazoria counties? If the Favorites list, did you append it from the main database, or did you create it manually? Also, have you verified that your location is correct in the scanner? If in doubt, try resetting it as well s the range, and see if that makes any difference.it has never worked as for as TXwarn P25 Trunked only on old systemsVHF like the HP1
firemik1;2933358 My HP=2 has never worked trying to monitor the TXwarn P25 Trunked System but only for older VHF systems like the HP1[/QUOTE said:Hello Firemik1, just as a very important test for everyone's diagnostic benefit please try the following steps:
1) Tap these steps: Menu / Manage Favorites List / Select Database to Monitor / Only Full Database.
2) Tap these steps: Menu / Set Your Location / Enter Zip Code / USA / 77422 / Accept (Brazoria Co Zip)
3) Tap "Range" / tap + to advance setting to say 10 or 15 miles just as a reception test for right now.
4) Tap these steps: Menu / Select Service Types / ( Enable the following types / Disable ALL other types):
Try only these for now: EMS Dispatch, Fire Dispatch, Fire-Tac, Interop, Law Dispatch, Law Tac, Law Talk
Tap Accept after you adjust your service types to see how this working database filter behaves for you ?
5) Tap Squelch setting and adjust your setting to only just 2 bars highlighted from the left (good for most)
6) Make sure at the top of your screen that "Atten" is not accidently enabled (Attenuation needs to be Off)!
Q: What is your HP-2's Firmware Version: 2.06 or higher ? (Menu/Advanced/tap down arrow/Version Info)
Q: Now tell us what and how your Uniden HP-2 receives after these diagnostic troubleshooting steps ?
Q: tell us if by chance if your HP-2 has the extra additional $50 Extreme Update Analyze Feature sets ?
Q: When you programed your custom favorites list did you enter either of these Simulcast sites below ?
Note: Simulcast Layer Sites carry all the traffic - other sites might only carry a fraction of the action !
note: Also try to tap and hold scanning on the "TxWarn P25 System" so we can focus only on this system.
Texas Wide Area Radio Network (TxWARN)
https://www.radioreference.com/apps/db/?sid=4563
Site # 054 (36) Galveston County Simulcast Galveston 769.44375 770.18125 770.78125 770.94375 771.89375 772.68125 773.18125 773.34375 773.94375c 774.28125 774.55625 774.80625a
Site # 058 (3A) Brazoria County Simulcast Brazoria 769.46875 769.93125 770.96875a 771.24375a 772.03125a 772.85625c 853.2875 853.550 853.9625
[/QUOTE][
I have answered the questions I know answers to..Not sure how to get firmware on scanner updated
QUOTE=Michael-SATX;2933491]Hello Firemik1, just as a very important test for everyone's diagnostic benefit please try the following steps:
1) Tap these steps: Menu / Manage Favorites List / Select Database to Monitor / Only Full Database. Done
2) Tap these steps: Menu / Set Your Location / Enter Zip Code / USA / 77422 / Accept (Brazoria Co Zip) Done , but set for my area 77510
3) Tap "Range" / tap + to advance setting to say 10 or 15 miles just as a reception test for right now. DONE
Tap Accept after you adjust your service types to see how this working database filter behaves for you ? DONE
5) Tap Squelch setting and adjust your setting to only just 2 bars highlighted from the left (good for most) DONE
6) Make sure at the top of your screen that "Atten" is not accidently enabled (Attenuation needs to be Off)! Already correct
Q: What is your HP-2's Firmware Version: 2.06 or higher ? (Menu/Advanced/tap down arrow/Version Info) I cannot download or change firmware on scanner itself, I did update the sentenal to 2.06
Note: Simulcast Layer Sites carry all the traffic - other sites might only carry a fraction of the action ! UNKNOWN, I created a favorite list of Galveston county agencies
note: Also try to tap and hold scanning on the "TxWarn P25 System" so we can focus only on this system. Did that..still not receiving any traffic
Sent via email, as both the *.zip file, as well as the *.hpe file, which can be imported directly into Sentinel.is it possible to send zip file by email kstellhorn@comcast.net every time I try creating a file it attempts to open in adobe
