I live in the fm 2978 /fm1488 area so I don't know how far "south" you are from me.I have great luck with Houston PD in Montgomery County TX but I live on the south part so your experience may vary. My BCD536HP scanner in my truck has trouble receiving it unless I'm on I-45 (could be an antenna issue) but my Harris gear picks it up no problem. Even my handheld picks it up when its listening to the right site. Houston PD is on the TXWARN RFSS site 3 and their talkgroups are much more common on the simulcast sites (Site ID 1-4) in P25 Phase 2 TDMA than the others. Site ID 5 broadcasts the MA talkgroups in P25 Phase 1 and this can be listened to all the time reliably. I haven't heard Houston PD on the Montgomery County simulcast site. If you just want the fire tone-outs it can be listened to on the UHF side (462.95000 & 460.57500) I cant remember which one off the top of my head.
Link for the yagi antenna? I listen to 800mhz mainly.Best bet is probably to aim a yagi towards Houston. This would of course presume base station use. I have seen a few Houston City talkgroups being pulled up through the MoCo or roamer sites, but nothing one could depend upon for full-time monitoring. Just the occasional affiliation.
A SOLID (good antenna, coax, etc) high quality mobile install should still receive either the COH phase 1 or phase 2 sites, especially in the south and south east parts of the county...portable not so much. The northern and far corners of Montgomery County would probably be a far reach though.
What site are you listening on?Not terribly far, I’m off 2978 and woodlands parkway, only about 5 miles but I still am able to hear the Houston PD talkgroups in that area with my Harris gear. My scanner tends to ignore the talkgroups but I think if I had a better antenna and line of sight I would be able to hear what I wanted to hear on the scanner side.
