Greetings all -
I was wondering if there is any information available about “who broadcasts from where” on the MPSCS system?
For example, I got back into listening about a year ago with a BCDx36 scanner. After getting it setup for Genesee County, the performance was pretty abysmal using the Genesee County simulcast tower. Only through some searching did I stumble on the fact that I could use the Holly tower, which is much closer.
I know that some IDs can be used Statewide. Others are more localized. I don’t plan to try and listen to the entire state.
But, it could be useful info when you’re in these bordering areas, which always seems to be my case.
Regards,
-Matt
Regards,
-Matt
